Posted (edited)
Hello!
I attempted to make a feedback loop plug for my Sammich, where the output is split between a female jack and a male TRS connector.
The image corresponds to the wiring, where the square oscillator (output of Sammich) is wired in parallel to the female output connector and pin 3 of a potentiometer.
Pin 1 of the pot is set to ground and the washer pin is wired to the male TRS connector that goes to the Input of the Sammich.
The wiring shows a mono connection but I've made it with a stereo pot so leftOut->leftIn and rightOut->rightIn and the 10k resistor just symbolises the input of the Sammich (no 10k on actual wiring, only for simulation purposes).
However, I cannot hear any difference with the pot turned each way, not even when activating the filter in on the patch loaded.
What am I doing wrong?
Cheers
/Macke
post-11123-0-32887500-1422709968_thumb.p
Edited by mackeSID
Yeah, i've seen it. I don't understand why he's chosen to wire pin 2 & 3 together like that.
I've used a 200k pot, doesn't seem like the value of the pot should matter very much since it's just voltage division.
What is it that you don't understand?
