julianf Posted March 11, 2015 Posted March 11, 2015 Two sets. Both have faults, so both cheap. Set #1 - Perfect, except for 5 holes not cut. This would be a pretty easy job to resolve - print out the panel on paper, overlay it, centermark the five holes, and drill them. With care, would result in a perfect panel, with not a whole load of effort. Photos - Set #2 - Call it a Halloween set? Gouged by the cutter. Is what it is. Good to be used, without any manipulation (ie you dont need to drill this one - its all spot on, except for the 'wound') Rear panel is not in the photo, but its included, and is fine (only the top got damaged) Photo - (i know there's only one photo, but the others were all wrong - ill try again if youre keen) Price - GBP 65 per set (ex delivery / fees) Both sets are the same cost, so its 100% up to you if you would like to drill the first set, and go that way, or would like to just have a panel that fits 'out of the box'
