jjonas Posted May 7, 2015 Posted May 7, 2015 Hi, is it possible to use MBSEQ4 to implement this hot tip from MBSID manual (or something similar)? "there is a simple trick which allows you to play a bassline and drum sequence in synch during a live session: just add an audio delay unit with t_delay=30 mS (e.g. VST based) to the SID outputs which are playing the basslines in order to compensate the timings." http://ucapps.de/midibox_sid_manual_d.html
TK. Posted May 10, 2015 Posted May 10, 2015 No, this isn't possible because the MBSEQ V4 based scheduler works MIDI tick based, not time based. Best Regards, Thorsten.
