Posted (edited)
Problems with the display of characters and letters. They are not right in the lines or even deleted.
I use Big_Font, with thin or normal is everything.
IMG_20151126_113524.thumb.jpg.39820cec10IMG_20151126_113639.thumb.jpg.02420566d6
IMG_20151126_113605.thumb.jpg.e3e284010dIMG_20151126_113622.thumb.jpg.6f7ab38992
IMG_20151126_113715.thumb.jpg.2645a7b7eb
Seting:
# MAP2 lcd_pos = 1: 1: 2
Event_receiver id = 5 type = SysEx Strom = "0xF0 0x00 0x00 0x66 ^ dev 0x12 ^ Cursor ^ txt56" range = MAP2 lcd_pos = 1: 1: 2 label = "& b"
MAP1 2 3 4 5 6 7 8 \
      12 13 14 15 16 17 18 \
      22 23 24 25 26 27 28 \
      32 33 34 35 36 37 38
MAP2 0 1 2 3 4 5 6 \
       8 9 10 11 12 13 14 \
      16 17 18 19 20 21 22 \
      24 25 26 27 28 29 30 \
      32 33 34 35 36 37 38 \
      40 41 42 43 44 45 46 \
      48 49 50 51 52 53 54 \
      56 57 58 59 60 61 62
MAP3 2 3 4 5 6 7 8 \
      42 43 44 45 46 47 48 \
      52 53 54 55 56 57 58 \
      62 63 64 65 66 67 68 \
      72 73 74 75 76 77 78
MAP4 1 2 3 4 5 6 7 \
            11 12 13 14 15 16 17 \
            21 22 23 24 25 26 27 \
            31 32 33 34 35 36 37 \
            41 42 43 44 45 46 47 \
            51 52 53 54 55 56 57 \
            61 62 63 64 65 66 67 \
            71 72 73 74 75 76 77
Could someone help me ???
That's only if I MIDI I / O and 2 Dinx turn MF_NG.
Dinx Can I deal when I MBHF_Core_V3.
The problem is the incoming MIDI events. John E. Finster had he solved differently about sysx the same problem in 2013, was not coming in amazement to me.
Why TK has not yet completed the remedial ??? :(
Greetings TOKEN_one
and I will thank you.
I apologize for the bad English.
With translator.
Also Ich bin jetzt von, von diesem Projekt.
Unterstützung ist hier sehr selten. Im bereich SEQ v4 und SID  ja.
egal Tschüss.
Edited by TOKEN_one
  • 3 weeks later...
the clarification of this issue is still on my TODO list.
Probably it's related to the way how the Y position is placed at the second line. For big fonts a special case has to be considered, this can only be changed in the firmware, and therefore I guess that I'm the only one who can help here...
