TOKEN_one Posted November 26, 2015 Posted November 26, 2015 (edited) Problems with the display of characters and letters. They are not right in the lines or even deleted.I use Big_Font, with thin or normal is everything.Seting:# MAP2 lcd_pos = 1: 1: 2 Event_receiver id = 5 type = SysEx Strom = "0xF0 0x00 0x00 0x66 ^ dev 0x12 ^ Cursor ^ txt56" range = MAP2 lcd_pos = 1: 1: 2 label = "& b" MAP1 2 3 4 5 6 7 8 \ 12 13 14 15 16 17 18 \ 22 23 24 25 26 27 28 \ 32 33 34 35 36 37 38 MAP2 0 1 2 3 4 5 6 \ 8 9 10 11 12 13 14 \ 16 17 18 19 20 21 22 \ 24 25 26 27 28 29 30 \ 32 33 34 35 36 37 38 \ 40 41 42 43 44 45 46 \ 48 49 50 51 52 53 54 \ 56 57 58 59 60 61 62 MAP3 2 3 4 5 6 7 8 \ 12 13 14 15 16 17 18 \ 22 23 24 25 26 27 28 \ 32 33 34 35 36 37 38 \ 42 43 44 45 46 47 48 \ 52 53 54 55 56 57 58 \ 62 63 64 65 66 67 68 \ 72 73 74 75 76 77 78MAP4 1 2 3 4 5 6 7 \ 11 12 13 14 15 16 17 \ 21 22 23 24 25 26 27 \ 31 32 33 34 35 36 37 \ 41 42 43 44 45 46 47 \ 51 52 53 54 55 56 57 \ 61 62 63 64 65 66 67 \ 71 72 73 74 75 76 77 Could someone help me ???That's only if I MIDI I / O and 2 Dinx turn MF_NG.Dinx Can I deal when I MBHF_Core_V3.The problem is the incoming MIDI events. John E. Finster had he solved differently about sysx the same problem in 2013, was not coming in amazement to me.Why TK has not yet completed the remedial ??? :(Greetings TOKEN_oneand I will thank you.I apologize for the bad English.With translator.******************************************************************Also Ich bin jetzt von, von diesem Projekt.Unterstützung ist hier sehr selten. Im bereich SEQ v4 und SID ja. egal Tschüss. Edited December 12, 2015 by TOKEN_one
TK. Posted December 15, 2015 Posted December 15, 2015 Hi,the clarification of this issue is still on my TODO list.Probably it's related to the way how the Y position is placed at the second line. For big fonts a special case has to be considered, this can only be changed in the firmware, and therefore I guess that I'm the only one who can help here...Best Regards, Thorsten.
TK. Posted December 21, 2015 Posted December 21, 2015 I found a solution to handle the Y position properly if the big font is used for SysEx based GLCD output Please try this version: http://www.ucapps.de/mios32/midibox_ng_v1_034_pre1.zip Best Regards, Thorsten.
TOKEN_one Posted December 22, 2015 Author Posted December 22, 2015 That was fast.It works SUPER TK You're the best.A Merry Christmas and a Happy New Year Greeting TOKEN_one
