Outis Posted November 29, 2015 Report Posted November 29, 2015 HI,I recently done a SEQ V4 (Wilba) which goes like a train, all is working very well but I would like to know if there is a way to lower the brightness of the LEDs through programming...Thanks a lot. Quote
Hawkeye Posted November 29, 2015 Report Posted November 29, 2015 It would be way easier to just desolder the currently installed resistors (next to the central wheel encoder) and solder in a higher resistance. E.g. if these are 220R resistors, try 1K... after opening the SEQ up, desoldering and resoldering would take about 10 minutes, the software approach, while theoretically possible, would take a LOT longer and you would have a non-standard firmware afterwards :-). Many greets and good luck!Peter Quote
