SynthAnthony Posted December 19, 2015 Posted December 19, 2015 I'm trying to hook up sammichSID to a Behringer BCF2000 for more hands on control. It should be straightforwards: all BCF2000 needs is some kind of an incoming MIDI message and it can then assign the corresponding message to a fader, encoder or button. But it seems like sammichSID doesn't send any MIDI data, when I tweak the parameters (only when I do a MIDI dump). Is it possible to configure it, so it can send MIDI messages when I change values in the menus? I went through the manual, but I can't find anything. Thank you,
jaytee Posted December 28, 2015 Posted December 28, 2015 Try getting the CTRLR panel working on your computer, then send tweaks from that to your BCF2000.
