mongrol Posted January 17, 2017 Posted January 17, 2017 I'm sure this has been asked before but I couldn't find anything about it in the manual or forum. Does Live Recording mode record CC parameter changes? I think this is called p-locks on Electron boxes. My Volca Keys does it as well. I presume if it does it would need a matching CC layer setup. My other question is, can it handle 2 MIDI-IN's? As in, my keyboard sends note data, and a "yet to be determined" knob controller sends CC's.
jjonas Posted January 17, 2017 Posted January 17, 2017 I'm not sure if you saw this already and it didn't answer your question, but just in case it's useful: "You can record CC messages live the same way you can record notes. There are two alternative conditions: either the incoming CC message number has to have a dedicated CC parameter layer already, or there is a CC layer that is currently 'off'. For example, an incoming CC#001 will be recorded to the first CC layer where there already are CC#001 messages, or if there is no such layer, the CC#001 message will be recorded into the first free CC layer. If there are no available CC layers, the incoming messages won't be recorded anywhere." (Beginner's Guide, 4.1.4., Live Recording) As to your second question, I'd guess that if your MIDI router settings (see the Guide, Appendix 3) are ok, it makes no difference where the incoming CC is coming from.
mongrol Posted January 17, 2017 Author Posted January 17, 2017 r0ck! Mr jjonas. I'm speed reading in too big jumps. I read over that bit and somehow missed it....focus mongrol, focus. :)
