ChinMuzik Posted February 4, 2017 Report Share Posted February 4, 2017 I had a small panel fabbed for the CORE, SID and DIN/OUT modules with the available layouts in the wiki. The fab house printed these as two layer boards but the drill outs show the vias for the bridges. Stupid question, the soldering guide instructs to solder the bridges.. but do these still need to be populated if it's already a 2 layer board? Quote Link to comment Share on other sites More sharing options...
latigid on Posted February 4, 2017 Report Share Posted February 4, 2017 To me, the available files show copper on both layers. Check with a multimeter? Quote Link to comment Share on other sites More sharing options...
ChinMuzik Posted February 4, 2017 Author Report Share Posted February 4, 2017 I'm just looking for continuity between the bridge points? Quote Link to comment Share on other sites More sharing options...
latigid on Posted February 4, 2017 Report Share Posted February 4, 2017 Yep, also you'll see the track drawn on the copper layer as well as the plated via. 1 Quote Link to comment Share on other sites More sharing options...
ChinMuzik Posted February 4, 2017 Author Report Share Posted February 4, 2017 (edited) I can't read layouts so I had no clue if there was a second layer or not. So I was confused when I saw the drill holes when the boards came. Thanks Latigid! Edit: I guess I should have known also from the traces underneath the board lol Learning is a slow process for me Edited February 4, 2017 by ChinMuzik Quote Link to comment Share on other sites More sharing options...
