Alasdair Moon Posted September 14, 2017 Posted September 14, 2017 (edited) Hi all, I tried to update my midibox today from 4.090 to 4.092 on STM32F4-Discovery I connected the micro usb and started the mios32 under my Linux Mint. (I have a 5v power-supply connected) USB Ports of my midibox seq are scanned and loaded ... QUERY gives the correct values Filebrowser can access SD-card If I send infos from my midibox to mios32 all works perfect When I tried to upload the new hex-file I get the ERROR .... FILE DOES NOT EXIST and that's it ... the "start" Button of MIOS32 stays grey What could it be? Only weird thing I see in the Infopage is the CPU-load that says 234% Greetings, Sascha Edited September 23, 2017 by Alasdair Moon
Alasdair Moon Posted September 20, 2017 Author Posted September 20, 2017 O.k., I maybe found the solution. Mios Studio 2 as well as CTRLR use Juce. Both Apps have problems opening files on my Linux Mint, and this might be cause by a Non-KDE Desktop Env. Will test this later this evening.
Alasdair Moon Posted September 23, 2017 Author Posted September 23, 2017 Yes, it is the Juce in Linux Mint ..... did the update via a windows 7 and all worked smooth.
