scrubber Posted October 17, 2017 Posted October 17, 2017 Hello I have nearly finished my lemur patch for the midibox Tia and am trying to work out how to set the cc messages that have the bits i have no trouble setting the 'regular' ones where you set the cc number then scale (0-127) or 0-64 positive/negative how do I set for example the Lfo mode: cc93 hex: 5dh bit 0 enables lfo Bit 1 sync assigned note events bit 2 sync all note events bit 6-4 waveform 0 sine 1triangle 2 saw 3 pulse 4 random example 11h =17 enable and triangle wave How do I set the bits? I don't understand how those example hex numbers were calculated or how to implement into my patch?
Hawkeye Posted October 18, 2017 Posted October 18, 2017 Hi there, some binary to decimal conversion will do it: E.g. if you want to set bit 0 in a 7-bit CC value (0-127), it would become (1), if you want to set bit 1, it would become (2), if you set bit 2, it would become (4) and so on. Add up these values to get to the result decimal value. For example, to set bits 3 and 5, the value would be 8 + 32 = 40, just send that as a regular CC value and you are good to go. https://en.wikipedia.org/wiki/Binary_number Many greets! Peter
