macsaif Posted September 25, 2018 Report Share Posted September 25, 2018 Hello, Is it possible to load snapshot without triggering the assigned MIDI command and witjoit executing of fwd_id? I need to do yhe following: 1. Load the snapshot (the defined values by no_dump) and do nothing - at the moment it is loading values than dumping, I need loading without dumping 2. Send 2 Progra change commands (based on the loaded values) one fkr ch1 and one for ch4 - solved in NGR 3. Wait 800ms - solved in NGR 4. DUMP SNAPSHOT - it is working, solved in ngr 5. Activate and deactivate senders based on the loadwd LED values - it is working, solved in NGR Is there any solution, or can I put it to wishlist for Midibox NG as Load_nodump_snapshot command? Frank Quote Link to comment Share on other sites More sharing options...
macsaif Posted October 4, 2018 Author Report Share Posted October 4, 2018 Really nobody has experience with that? Who can I contact directly, do you think? Frank Quote Link to comment Share on other sites More sharing options...
macsaif Posted July 29, 2019 Author Report Share Posted July 29, 2019 The other solution of my problem could be the loading of only few defined parameters not all the snapshot. In that case I could load parameters which are sgoring the program change numbers which I need to send the sound module than load the whole snapshot and send cc numbers automatically at loading. Quote Link to comment Share on other sites More sharing options...
