goyousalukis Posted November 27, 2018 Posted November 27, 2018 Hey guys - a few quick questions. I finally soldered up the two line driver boards. MBSeq 4 using the WILBA front panel. Question 1 - do I use straight through cables for the connections from the Line Driver to the core and to the Front Panel? Question 2 - do I still use the modified cable to the AOUT from the line driver? Question 3 - Does the MBSeq still function if the other end of the line driver is not connected? In other words, If I connect the two ribbon cables to the core and front panel, but do not hook up the 25 conductor cable, should the MBSeq work fine? Right now, as soon as I connect the line driver to the front panel, my front panel goes wonky, and the buttons do not work correctly. I have of course gone over the transmitter board and double checked that I made no mistakes. Thanks, Justin
goyousalukis Posted November 27, 2018 Author Posted November 27, 2018 Disregard - I went back to the uCapps page and see all the answers to my questions. I did not have the jumper stuffed.
