TheMentat Posted September 13, 2019 Report Share Posted September 13, 2019 Hi All, I'm new to the whole SEQ system, so I've been working through some of the tutorials on the uCApps site. One thing that I've run into is that there are a few changes to the front panel since a lot of these tutorials were written. Specifically, I'm trying to easily switch drums (eg, from BD to SD) on a drum track. TK's Tutorial #2 suggests I should be using the LAYER C button, which doesn't seem to exist. Is there a new button somewhere? Perhaps the workflow for this has changed? Any other major changes to workflow that are introduced by the V4+ that I should keep in mind when working through the documentation? Thanks! Quote Link to comment Share on other sites More sharing options...
TK. Posted September 13, 2019 Report Share Posted September 13, 2019 Hi Mentat, Which frontpanel are you using? The function still exists, just the button has been renamed to Parameter Layer C. If you are using a MIDIphy frontpanel, drums can be directly selected with the 16 additional "select" buttons in "instrument" mode. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TheMentat Posted September 14, 2019 Author Report Share Posted September 14, 2019 Ahhh perfect. Yes, I am using the midiphy panel. thanks TK! Quote Link to comment Share on other sites More sharing options...
