Tom71 Posted November 2, 2019 Posted November 2, 2019 (edited) Hello How can i find the right firmware for Pic16F88 for the Quad IIC Midi Board? Regard Tom71 Edited November 2, 2019 by Tom71
latigid on Posted November 2, 2019 Posted November 2, 2019 Here you go: http://ucapps.de/mbhp/mbhp_iic_midi_v1_0c.zip http://ucapps.de/mbhp_iic_midi.html is the parent page with all info.
Tom71 Posted November 2, 2019 Author Posted November 2, 2019 Ok. I was not sure that this is the right download for the quad board. Has every PIC on the quad board the same hex file to burn or must be set a different ID in the firmware?
latigid on Posted November 2, 2019 Posted November 2, 2019 You're welcome. Device IDs are hardwired using IO pins directly on the PCB (or selected with jumpers on oldschool I2C modules).
Tom71 Posted November 3, 2019 Author Posted November 3, 2019 Thank you latigid on Now i see the different on pin 12/13/14 in the schematic.
