Working on a front panel on a MIDIbox MB-6582 and on the reference panel the modulation matrix is marked 1-8 but TK's docs list the env and LFO mods. Just wanted to make sure that this right before I get it made.
I had a drive crash and lost the Kicad project, but I still have the slightly modified DXF file that I worked on, which was derived from Listen202's version.
https://1drv.ms/u/s!AtmSvwylfFJagkpl5QlWo9tIUbJ0?e=mamgPG
Working with DXF's in KiCAD requires several steps:
1) In the KICAD PCB tool, you'll import Listen202's DXF file into the Edge.cuts layer
2) make sure to size it properly, (approx. 232.3mm x 163.2mm)
3) Delete all of the graphics from this layer, but keep all
