Guest massi Posted January 20, 2004 Posted January 20, 2004 hi ,Im finishing now my midibox 64 with 1.0 firmware.I still have unplugged all the faders and buttons couse when I switch on the core with twoo ainx ,the display is fine(shows the count up and version),but when I connect the dinx module without any button plugged,the display doesnt start at all.is my dinx in short or what?Thanks for the helpmassi-newbieItaly
pay_c Posted January 20, 2004 Posted January 20, 2004 Welcome!! :DYeah, should be that (Does the 7805 on the core get hot?). Measure the resistance between GND and 5V on your DIN to go sure.
Guest massi Posted January 20, 2004 Posted January 20, 2004 Thanks for answering Pay_c :)I ve tested all the +5 and ground pins on each module,but my problem is still there.Maybe i should connect the 4 buttons for commands first.Anyway the 5 volts are correct everywhere :(
