Hi there all, I was wondering if it could be possible to connect a simple midi out led monitor directly on the core ?
The idea is (I can live without it) it would be cool that at least one LED tells me that the box is On, and if its monitoring the midi out, I'll be aware if some infos failed to be sent.
thanks
defred
By the way, I found a new set of potis for my box, I'll try setting up the AIN again today. See the problem herehttp://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1073512427
Yepp, just get the schematics of the LTC and only use one of those 74HC00s.
Did that, too, no prob to build that up on a breadboard.
