k2z3k0 Posted May 16, 2021 Report Share Posted May 16, 2021 hello everybody I noticed that when randomizing clean empty track LayA(notes) with value 1,(TrgAll),it makes -1 / +1 deviations from 64 which is E-3. Now initial note for track is 60 (C-3) and this makes a bit strange situation ,that randomizer starts from other point then initial note value(60) Also i want to ask if there is a way to set default initial value(now 64,C-3) of notes,there is initial value for CC(option 24/33),maybe would be great to have one, also for notes. And maybe would be great if randomizer deviate starting from that default init value thank you in advance best regards Kazik Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted May 17, 2021 Author Report Share Posted May 17, 2021 u8 base, range; seq_par_layer_type_t layer_type = SEQ_PAR_AssignmentGet(visible_track, layer); if( layer_type == SEQ_PAR_Type_Length ) { base = 16; range = ((par_layer_range[layer] >> 2) - 1); // -> +/- 16 if( !range || range > 128 ) // (on underrun...) range = 1; } else { base = 0x40; <- WILL THIS DO THE TRICK? range = par_layer_range[layer]; } Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted May 19, 2021 Author Report Share Posted May 19, 2021 hi everyone is possible to generate random values only for steps with trig? Quote Link to comment Share on other sites More sharing options...
