sammichSID (running MIDIbox SID v2) MIDI connection drops out ("Undefined External Error")
Hi all,
New to the MIDIbox SID / sammichSID, and to the forum, but definitely not to MIDI, computers or music production in general. I got the sammichSID a few days ago and I can't seem to use it for more than 5-10 minutes at a time before it stops receiving MIDI. My DAW (BitWig Studio) throws up this error and I have to un/replug my MIDI interface to get the connection back. I know, I know; that suggests a Windows issue, which it might very well be, but..
I suspect the MIDIbox SID / sammichSID-unit is the culprit (something in its MIDI receive handling) because I am literally surrounded by synths from the 70s and up until now, and this is the only time I've ever had this problem.
So far I've tried:
  • Using a different MIDI output on the Alyseum
  • Using a different MIDI interface
  • Played MIDI notes manually
  • Sent recorded MIDI notes from the DAW timeline
  • Running the MIDIbox SID in mono mode
  • Taken out one of the SIDs and running it in mono mode
  • Tried two different PSUs (the current one is a proper quality Elektron 12VDC one that I normally use on the Analog Heat)
  • Checked the MIDI output from BitWig Studio with MIDI-OX just to check if it for some reason was sending something bogus, which it wasn't
..and I'm none the wiser. I know MIDI is a pretty dumb protocol, but the error reported comes from the Windows MIDI Mapper, and when I Googled around a bit I found this error tends to happen in a wiiiiide variety of situations, none of which apply to my particular hardware setup of course, so again I'm none the wiser.
That's why I wanted to check in with the forum here to see if anyone has been through something similar. I searched  through the forum for the phrase "Undefined External Error", but nothing came up so while I'm not hopeful that a solution exists, perhaps someone with more experience than myself with this particular unit has some suggestions.
