Guest Thomas_Holley Posted February 25, 2004 Posted February 25, 2004 I want to use an LTC module with my MIDIBox SID (quad). If I use it as an extra MIDI port (MAX232 out), do I connect it to the master CORE module only, or to all CORE modules?
TK. Posted February 25, 2004 Posted February 25, 2004 Hi Thomas,it has to be connected to the CORE module, only.See also this special diagram for MIDIbox SID:(more diagrams can be found under http://www.ucapps.de/mbhp_ltc.html)Best Regards, Thorsten.
Guest Thomas_Holley Posted February 25, 2004 Posted February 25, 2004 I think I am clear now. The LTC should be connected in parallel tp J11 of all CORE modules as the diagram shows.
