midibox chain
Guest djDim
sure, this is possible on this way:
LTC J1:MI -> MIDIbox Plus Rx Pin
MIDIbox Plus Tx Pin -> MB64 Rx Pin
MB64 Tx Pin -> LTC J1:MO
Hope that this short description is clear enough (just compare the schematics of the MBHP core, the LTC module & MIDIbox Plus). I will draw a diagram if required...
Hi Thorsten,
Thanks for your reply.
The idea is to use only the serial port for all midiboxes.
I meant Midibox16E no midibox plus but that should not
change the configuration.
Do I have to omit any optocuplers on either core pcb's?
If so which?
Thanks
Alright - yes, for MB16E it's the same.
You have to omit all optocouplers. They are only for "common" MIDI lines, which are working as opto-isolated "current loop". So long as you are wiring digital Rx/Tx signals, no additional components are required between MIDI IN and OUT.
