Ian_Hurlock Posted May 9, 2004 Posted May 9, 2004 Hi thereThis ones probably for you TKI have been working on that Live controller based on the 64E.Faders and enc's are working now but I would like to revisit the flashing led scenario as visited a long time ago.I have made changes to the SR Service prepare and the App defines as follows.USER_SR_Service_Prepare ;; call LEDrings handler call MB64E_LEDRINGS_Handler ;; branch to the Rx/Tx LED handler goto MIDI_RXTX_Handlerled_FLASH_Handler ;; increment counter incf DOUT_led_CTR, F ;; skip next block if led should not flash IFCLR DOUT_led_FLASH_ENABLE, 0, rgoto led_FLASH_Handler_Skip0 ;; skip if DOUT counter < 128 (bit #7 not set), this leads to a ;; flashing frequency of 1 / (128 * update_cycle) = 1 / (128 * 1 mS) = ca. 8 Hz IFCLR DOUT_led_CTR, 7, rgoto led_FLASH_Handler_Skip0 ;; get value of led at DOUT #0 movlw 0x00 call MIOS_DOUT_PinGet ;; result in MIOS_PARAMETER1, invert it comf MIOS_PARAMETER1, F ;; write back result to DOUT #0 movlw 0x00 call MIOS_DOUT_PinSet led_FLASH_Handler_Skip0 ;; thats all return ;; LEDring patterns;; ==========================================================================LEDRING_PATTERN_0 EQU 0LEDRING_PATTERN_1 EQU 1LEDRING_PATTERN_2 EQU 2LEDRING_PATTERN_3 EQU 3;; ==========================================================================DOUT_led_ctr EQU 0x021DOUT_led_FLASH_ENABLE EQU 0x022 ;; free memory for user applications: ;; 0x010-0x37fThis did not seem to work and gave me a pile of errors. 12 to be exact.Could you give me a few hints here please.Thanks TKRegardsIan
TK. Posted May 10, 2004 Posted May 10, 2004 Hi Ian,what's the content of the .err file? (If you've assembled the main.asm, the name of the error file is "main.err")Best Regards, Thorsten.
Ian_Hurlock Posted May 10, 2004 Author Posted May 10, 2004 Hi TKI have forwarded the err file to via email for your perusal.Thanks Ian
TK. Posted May 10, 2004 Posted May 10, 2004 Hi Ian,I found some warnings in the .err file like: Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 571 : Found opcode in column 1. (incf) Warning[206] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 574 : Found call to macro in column 1. (IFCLR) Warning[206] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 577 : Found call to macro in column 1. (IFCLR) Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 579 : Found opcode in column 1. (movlw) Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 580 : Found opcode in column 1. (call) Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 582 : Found opcode in column 1. (comf) Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 584 : Found opcode in column 1. (movlw) Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 585 : Found opcode in column 1. (call) Warning[203] C:\PROG STUFF\MIDIBOX64E_V2_1\MAIN.ASM 589 : Found opcode in column 1. (return) it seems that the assembler fails since there are no space characters between the instructions and the first column. Therefore the assembler cannot determine if the "word" at the beginning is really an instruction (like incf) or a label (like USER_SR_Service_Prepare)Tip: just add TAB characters before every instruction, and the assembler should pass. If not, check the .err file againBest Regards, Thorsten.
