Rigo Posted March 9, 2006 Posted March 9, 2006 Well something terrible happenedI dont know what I did wrong un-soldering the AIN module, but now the CORE is not working.now the midi-ox input shows a lot of zeroes every two secondsSomething like the following:00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00and now the rectifier and regulator get very hot to the touch.any suggestions?
illogik Posted March 9, 2006 Posted March 9, 2006 heythis is happening with only the core/no ain connected?then you've probably made a short circuit between some points on J5 or J6 on the core module; check it well with a multimeter before you power up againgoodlukk
Rigo Posted March 10, 2006 Posted March 10, 2006 thank you I will get some result for that chekcing tomorrow=)
Rigo Posted March 20, 2006 Posted March 20, 2006 It is finally DONE , I Had to buy a new core and ain module,since I think I fried the pic and regulator nothing worked , yesterday I recived both modules and started the soldering and after six hours everything was soldered, 5 mins to burn and !!!!VUOALA!!!!!! everything works to perfection, thank you all you guys, TK, Raphael, and Tim. Thank you. :) :) :) :) :) :) :) :) :) :) :) :) :) ;D ;D ;D ;D ;D ;D ;D ;D ;D
