Connecting buttons and encoders to different pins
Guest kostix
Hi guys !
I finally have a working MBSEQ, but the back side of the panel is like a "cable heaven",  hundreds of cables all over everywhere, and it looks very messy
so i decided to mount the DINS on top of each section of buttons (i'll try post pics sometime).
The thing is, i need to connect the buttons and encoders to different pins on the DINs, not like the original design, but adapted to mine.
This would go something like this:
encoders 1-8, GP buttons 1-8, f1, f2, f3, f4, menu, select and exit buttons would go to 1 DIN module
encoder 9-16, GP buttons 9-16, scrub, metronome, stop, pause, play, rew, fwd to  second DIN module
and the jog wheel + the rest of the buttons (layers, patterns, edit , mute etc) on the third DIN.
Is this possible ?
I read somewhere bout modifying the code for the buttons assignments, but i'm not sure about the GP buttons and encoders ..  are they handled same way as the other buttons ?
if someone could point me to the exact places of code to modify, I would greatly appreciate it !
i think thats it
thanks in advance !
Guest kostix
Hi guys !
Is this possible ?
i think thats it
thanks in advance !
Check, calculate new placements in DIN chain and modify:
mios_tables.inc
(DIN_ENTRY = buttons, ENC_ENTRY = encoders)
setup_mbseqv2.asm
(same, plus DEFAULT_GP_DIN_SR* = GP buttons)
and
main.asm (for DEFAULT_GP_DIN_SR* = GP buttons)
I hope I'm correct ;) (and you can make it)
Bye, Moebius
mios_tables.inc
setup_mbseqv2.asm
and
Bye, Moebius
Guest kostix
Thank you ! :)
So basically the order of the connections doesnt matter at all, as they are read sequencially ?
I mean, like the jog wheel is connected to the first shift register,  same way I could connect it to the last one on the chain, and with correct assignments it will work with no problems ?
There is no priority ?
thanks again
gotta write down on paper the correct assignments and then start the tedious soldering of hundreds of joints :)
best wishes !
Guest kostix
Thank you ! :)
thanks again
best wishes !
Hi.
This I'm not sure of. (Note to myself: MUST LEARN MIOS).. But I'm sure it won't affect performance anyway (?!) ;)
Bye, Moebius
Hi.
Bye, Moebius
Guest kostix
Its PERFECT!
It WORKS !
;D
oh my oh my
and now its looking so beautiful inside
cant wait to take some pictures
thanks for the help
really appreciated!
gone for some more testing
Guest kostix
Its PERFECT!
It WORKS !
;D
oh my oh my
thanks for the help
really appreciated!
