robin303 Posted September 5, 2004 Posted September 5, 2004 I've got a little problem getting the bank stick bank-switching to work on my MidiBox 64. I have a row of 16 buttons on my box which I want to assign as bank-switch buttons. I also have two buttons which I want to assign increment/decrement bank feature. So I edited my configuration file like this: # bankstick bank 1-16 buttons 9 = FF 02 00 @OnOff 10 = FF 02 01 @OnOff 11 = FF 02 02 @OnOff 12 = FF 02 03 @OnOff 13 = FF 02 04 @OnOff ..etcetera... and # bankstick bank +/- buttons 47 = FF 02 10 @OnOnly # Save, Decrement Bank without overflow, Restore 48 = FF 02 12 @OnOnly # Save, Increment Bank without overflow, Restore When I press one of the buttons, the display shows meRobins bankAct. Bank: 1But the bank does not change! :(When I switch banks within the midibox menu, everything works perfectly... What's wrong?
TK. Posted September 6, 2004 Posted September 6, 2004 Hi Robin,thanks for the input - I just found an error in the mb64_sfb.inc file (the same error exists in the MIDIbox64E and MIDIbox MF application).Quickfix: open this file, search for MB64_SFB_Handler_02 (or go directly to line 86) and change: ;; branch to the end if no bankstick available IFSET MB_STAT, MB_STAT_USE_BANKSTICK, rgoto MB64_SFB_Handler_02_Msg to: ;; branch to the end if no bankstick available IFCLR MB_STAT, MB_STAT_USE_BANKSTICK, rgoto MB64_SFB_Handler_02_Msg hope that this helps!Best Regards, Thorsten.
robin303 Posted September 6, 2004 Author Posted September 6, 2004 Worked like a charm ;DThanks once again, TK!
