robin303 Posted September 5, 2004 Report Share Posted September 5, 2004 I've got a little problem getting the bank stick bank-switching to work on my MidiBox 64. I have a row of 16 buttons on my box which I want to assign as bank-switch buttons. I also have two buttons which I want to assign increment/decrement bank feature. So I edited my configuration file like this: # bankstick bank 1-16 buttons 9 = FF 02 00 @OnOff 10 = FF 02 01 @OnOff 11 = FF 02 02 @OnOff 12 = FF 02 03 @OnOff 13 = FF 02 04 @OnOff ..etcetera... and # bankstick bank +/- buttons 47 = FF 02 10 @OnOnly # Save, Decrement Bank without overflow, Restore 48 = FF 02 12 @OnOnly # Save, Increment Bank without overflow, Restore When I press one of the buttons, the display shows meRobins bankAct. Bank: 1But the bank does not change! :(When I switch banks within the midibox menu, everything works perfectly... What's wrong? Quote Link to comment Share on other sites More sharing options...
TK. Posted September 6, 2004 Report Share Posted September 6, 2004 Hi Robin,thanks for the input - I just found an error in the mb64_sfb.inc file (the same error exists in the MIDIbox64E and MIDIbox MF application).Quickfix: open this file, search for MB64_SFB_Handler_02 (or go directly to line 86) and change: ;; branch to the end if no bankstick available IFSET MB_STAT, MB_STAT_USE_BANKSTICK, rgoto MB64_SFB_Handler_02_Msg to: ;; branch to the end if no bankstick available IFCLR MB_STAT, MB_STAT_USE_BANKSTICK, rgoto MB64_SFB_Handler_02_Msg hope that this helps!Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
robin303 Posted September 6, 2004 Author Report Share Posted September 6, 2004 Worked like a charm ;DThanks once again, TK! Quote Link to comment Share on other sites More sharing options...
