Mudo Posted September 8, 2004 Report Posted September 8, 2004 ...Hello,I'm mudo and it's my first post.My question is: How can I convert my mixer crossfader (mono) in a stereo one. I need that the crossfader be the same. It's possible??thanksMudo... ???
Mudo Posted September 20, 2004 Author Report Posted September 20, 2004 ...Nobody has the answer or nobody understood the question???... :-X
gillesdeshays Posted September 20, 2004 Report Posted September 20, 2004 Can you say more about this ... ?I'm not sure to understand what you asked ....
jimhenry Posted September 20, 2004 Report Posted September 20, 2004 You might want to ask the question in Design Concepts with a better explanation of what you are trying to accomplish. MIDIfication is mostly people who are connecting on/off switches to MIDIfy keyboards and organ consoles. There is not as much experience with continuous controllers like faders here as in other areas of the forum.
Mudo Posted October 17, 2004 Author Report Posted October 17, 2004 ...Hello guys and sorry for the wait...My inet connection was broken...I would to know how to transform one mixer fader in one midi fader. what is/are the diagram/components that I need?Sorry about my poor english.Thanks a lot!!!...
Sephult Posted October 22, 2004 Report Posted October 22, 2004 The faders normally used in the midibox are 10k ohm faders. There are ways to utilize other rated faders, and I believe there are other posts in the forum about them. You could just use a core and an AIN module and setup the fader for a midi controller..This setup is only for midi use (not audio/midi fader), although you could probably find a way using motorized faders. I am not shure what problems you would run into tapping the fader for the AIN and running audio through however.-Hope this helps some
