robin303 Posted September 12, 2004 Posted September 12, 2004 This afternoon, I have added two banksticks to my midibox64 (which already had one functioning bankstick). So now there are three of them in my box. But I can't seem to find them! I made sure that the DEFAULT_BANKSTICK_CS setting in main.asm is set to -1.How can I verify if MIOS can access the extra 32 banks? Where do I find them?Once I get it to work, I would like to write a meta event that can copy bank a from bankstick b to bank x on bankstick y. Is this possible?Thanks for any help :)
TK. Posted September 12, 2004 Posted September 12, 2004 Hi Robin,for MIOS a BankStick is just a data storage, it doesn't take care for the data which is saved in the EEPROM. Therefore MIOS cannot tell you if you've 32 extra banks or not, it can only tell you if the second and third BankStick is accessible or not. The easiest way to do this is to request the BankStick content of BankStick #2 and #3 with the SysExBox tool. If MIOS transmit 32 blocks, the BankSticks are connected correctly, if MIOS returns an error code, then check your circuit.For the MIDIbox64 application each BankStick contains 16 banks. This application is programmed in a way that you don't need to select the BankStick, you only need to select bank 17-32 for BankStick #2, 33-48 for BankStick #3, etc...This means also that you are already able to copy data between multiple BankSticksBest Regards, Thorsten.
robin303 Posted September 16, 2004 Author Posted September 16, 2004 Thanks for the xplanation, I tried it out and all my 4 banksticks seem to be working perfectly :)Now, some more challenge, I hope you can help me on the way with this next thing. I'm really anxious to try and learn how to program my box. Let's say I would want to copy a "preset bank" into a "working bank".... I have created some preset banks to control different instruments in Reason. So there's one bank configured for the Mixer, one for the Dr.Rex, one for the NN-19 etcetera. I have stored these preset banks in bank 51 to bank 62 of my midibox64. I also have 16 "working banks", stored in bank 1 to 16. Now I would like to create a metaevent to load one of the "preset banks" into the currently selected "working bank": MB64_META_Handler_03 ;; input value 51-62 (0x33-0x3E) in MIDI_EVNT_VALUE ;; This will copy the SOURCE bank n to DESTINATION current_bank ;; 51 - reMix module 57 - RV7000 module ;; 52 - Subtractor module 58 - Scream4 module ;; 53 - Malström module 59 - BV512 module ;; 54 - NN-19 module 60 - Small FX modules ;; 55 - Dr:rex module 61 - MATRIX module ;; 56 - reDrum module 62 - General controllers ;; Only continue if the current bank is a "working bank" (between 1 and 16) to avoid overwriting the preset banks. movlw 0x10 ;Set W to 17 IFGEQ MB_BANK, W, rgoto MB64_META_PATCHLOAD_NOTOK ;If MB_BANK >= 17 then goto MB64_META_PATCHLOAD_NOTOK error message movf MB_BANK, W ;store the current bank number in W (this is the TARGET of the copy action) movff MIDI_EVNT_VALUE, MB_BANK ;change current bank to bank MIDI_EVNT_VALUE call MB64_BANK_CopyFromExternal return This is not working. When I trigger the metaevent while I'm in "working bank" 4, I do see the *** snapshot *** message, but after this the midibox returns being in bank 1 without any evidence of a copy actions having taken place. :-/Do you see any mistakes in my code?
TK. Posted September 17, 2004 Posted September 17, 2004 strange. in IFGEQ I would replace W by ACCESS, but this isn't the reason (both constants are 0)You could add following code: movlw 0xf0 ;; for debugging call MIOS_MIDI_TxBufferPut movf MB_BANK, W andlw 0x7f call MIOS_MIDI_TxBufferPut movff MIDI_EVNT_VALUE, WREG andlw 0x7f call MIOS_MIDI_TxBufferPut movlw 0xf7 call MIOS_MIDI_TxBufferPut before the last block, and movlw 0xf0 ;; for debugging call MIOS_MIDI_TxBufferPut movf MB_BANK, W andlw 0x7f call MIOS_MIDI_TxBufferPut movlw 0xf7 call MIOS_MIDI_TxBufferPut before the return for debuggingBest Regards, Thorsten.
