Jurbo Posted September 21, 2004 Report Posted September 21, 2004 Is the SID module supposed to put out a test melody when I turn it on (I think I read something like that somewhere on the forum)? I finally hooked up my first core and SID module, and I don't get any test sounds from it at startup, but I can play the thing using the MidiOx keyboard, getting a loud and clear sound.Should I be worried or is everything ok? ??? Quote
goyousalukis Posted September 22, 2004 Report Posted September 22, 2004 On BootUp, the MidiBox Sid only plays the startup melody if you have a bankstick attached. If you insert the bankstick after it is running, you hear it ascending and also if you remove it it plays descending.Justin Quote
Jurbo Posted September 23, 2004 Author Report Posted September 23, 2004 Ok, now I have a Bankstick with 2 memory modules (24LC256) attached... I got the rising sound on startup, plus a steady blip-blip-blip-blip when the machine formatted the Bankstick... I guess it will format the other memory module once I'm able to switch modules (don't have any controls hooked up yet.)...Thanks. :) Quote
