[MIDI_IN]
# Output Pin 1-4 assigned to Channel 1
   1 =  C0 00
   2 =  C0 01
   3 =  C0 02
   4 =  C0 03
Does the above mean that when I send the control change message  00 that pin 1 will be active?
Now if I alter the above to
[MIDI_IN]
   1 =  C0  90 3C 47
  that when the note middle c is played on channel 1 that pin one will be active? or is there more code needed? and how do I get the pin to turn off once its on? thanks for holding my hand.
