toggle switches
does any one know if its possible to use 3 position toggle switches (ON/OFF/ON) to select different inputs? if you understand what i mean?
say if i'm using ableton, and i want to use a 3 position toggle switch to assign a channel to either side of the cross fader such as SIDEA/OFF/SIDEB.
any ideas?
cheers,
bod.
Yepp, that´s no prob. I used that one often in my analoge modular Synthi (a Modulor 2000).
Just be sure to clamp all grounds together (without ground loops!) and use that switcher to route the signal (analoge signal).
No prob at all.
thanks mate, think i need to learn a bit more about this before i go connecting them all.
Guest
Reply to this topic...
