rocofolie Posted October 12, 2004 Posted October 12, 2004 Hi ,i ve just one question in which model of (midi or audio) table ( ea: roland ) are used motor faders ALPS RSAON11M9 10KB ( linear ) 100mm with touch sensor ?I ve the same uqestion with the encoder ALPS STEC 16B24 ?I ve found a guy who can find them but he want to know an existing table with this ....Do u now what i mean ?? ( i m french sorry ) :-/Thanks
rocofolie Posted October 13, 2004 Author Posted October 13, 2004 For exemple what are the motor fader in the Yamaha 02R ? or un the Tascam us 2400 ?? ???
Sephult Posted October 13, 2004 Posted October 13, 2004 You should use linear for the midibox, and nonlinear for audio. As for "table" I am unsure. I really don't think there is much difference as long as you are using linear for a Midibox. Using the linear you can access all the values evenly, from top to bottom. With non-linear you you run into not being able to select values individually in certain areas of the fader.Hope it helps-Don't worry, My only language is English and I have problems myself ;)
smashtv Posted October 13, 2004 Posted October 13, 2004 Hi ,i ve just one question in which model of (midi or audio) table ( ea: roland ) are used motor faders ALPS RSAON11M9 10KB ( linear ) 100mm with touch sensor ?I ve the same uqestion with the encoder ALPS STEC 16B24 ?I ve found a guy who can find them but he want to know an existing table with this ....Do u now what i mean ?? ( i m french sorry ) :-/ThanksIf I'm reading correctly he's asking for part numbers for the motorfaders and encoders that some of the commercial control surfaces/mixers/studio-in-a-box units use.It's a good question too, which might help make the quest for cheap touch sensitive motorfaders a little easier. ;)Best!Smash
rocofolie Posted October 13, 2004 Author Posted October 13, 2004 Don't worry, My only language is English and I have problems myself lol ;DSo in fact i want to use linear fader .Smash Tv i think that you understand what i mean ...For exemple i ve seen that the Tascam US 2400 use 24 motor fader with touch sensor but i don t know what model is ...Perhaps it s a cheap model ,i d on t know .
pilo Posted October 14, 2004 Posted October 14, 2004 ...make the quest for cheap touch sensitive motorfaders a little easier.Don't forget that the cheap motor fader quests is long and hard ;)took me one year to found affordable one.I think the best way to know which MF is used in commercial stuff, is to look in those.
rocofolie Posted October 14, 2004 Author Posted October 14, 2004 :-[I think the best way to know which MF is used in commercial stuff, is to look in thoseIt s true but i ve not all the model at home , in fact i have 0 model lolAnd i don t think that in a shop i can open our table lol :-/
