Does anybody know an elegant way to do this?
MIOS supports 4bit LCD mode on HD44780 controllers, and KS0066 seems to be compatible.
To set data communication in 4 bit mode, you have to override settings made by MIOS_LCD_TypeAutoSet function at startup. This can be done by MIOS_LCD_TypeSet function, read MIOS functions page:
http://www.ucapps.de/mios_fun.html
My uneducated guess:
Appending (quoting MIOS function reference):
       movlw        0x37 | 0x80        ; E1: D.7, 4bit interface
       movwf        MIOS_PARAMETER1
       movlw        0x24 | 0x80        ; E2: C.4, 4bit interface
       movwf        MIOS_PARAMETER2
       movlw        0x00                ; LCD type 0
       call        MIOS_LCD_TypeSet
In main.asm of the application, in "USER_Init" section ,will do ;)
Bye, Moebius
p.s. Be sure to check MIOS function reference for minor hardware changes needed! ;)
When you get your LCD up and running, you should try the LCD Benchmark application and post your findings. I am interested in what the results are for a 4 bit mode.
