ksir Posted May 13, 2024 Posted May 13, 2024 Good morning SetBankOfHwId only works on encoders? I tried on fader and Switch without result
ksir Posted May 15, 2024 Author Posted May 15, 2024 (edited) I understood I have to use set_active . I managed to make it work on encoder and push button set_active (id)ENC:10 1 set_active (id)BUTTON:117 1 I didn't succeed on Ainser, I tried: set_active (id)AINSER:133 1 #EDIT: There were errors in my code. It works now. The code below works Quote #NGC # EVENT id= 0 hw_id= 0 fwd_id=LED:0 type=CC chn= 0 cc= 0 button_mode= Toggle range= 0:127 fwd_to_lcd=1 rgbled_pattern= 0 hsv= 359:100:10 # Ju_Box RESET_HW # LCD message after load #LCD "%C@(11:2:2)READY." #Appel des BANKS EVENT_BUTTON id= 1001 hw_id= 29 type=Meta button_mode= OnOnly meta=RunSection:1 EVENT_BUTTON id= 1002 hw_id= 30 type=Meta button_mode= OnOnly meta=RunSection:2 EVENT_BUTTON id= 1003 hw_id= 31 type=Meta button_mode= OnOnly meta=RunSection:3 EVENT_BUTTON id= 1004 hw_id= 32 type=Meta button_mode= OnOnly meta=RunSection:4 EVENT_BUTTON id= 1005 hw_id= 61 type=Meta button_mode= OnOnly meta=RunSection:5 EVENT_BUTTON id= 1006 hw_id= 62 type=Meta button_mode= OnOnly meta=RunSection:6 EVENT_BUTTON id= 1007 hw_id= 63 type=Meta button_mode= OnOnly meta=RunSection:7 EVENT_BUTTON id= 1008 hw_id= 64 type=Meta button_mode= OnOnly meta=RunSection:8 #encoder_hardware_configuration ENC n= 1 sr= 1 pins=1:0 type=non_detented ENC n= 2 sr= 1 pins=3:2 type=non_detented ENC n= 3 sr= 1 pins=5:4 type=non_detented ENC n= 4 sr= 1 pins=7:6 type=non_detented ENC n= 5 sr= 2 pins=1:0 type=non_detented ENC n= 6 sr= 2 pins=3:2 type=non_detented ENC n= 7 sr= 2 pins=5:4 type=non_detented ENC n= 8 sr= 2 pins=7:6 type=non_detented ENC n= 9 sr= 5 pins=1:0 type=non_detented ENC n= 10 sr= 5 pins=3:2 type=non_detented ENC n= 11 sr= 5 pins=5:4 type=non_detented ENC n= 12 sr= 5 pins=7:6 type=non_detented ENC n= 13 sr= 6 pins=1:0 type=non_detented ENC n= 14 sr= 6 pins=3:2 type=non_detented ENC n= 15 sr= 6 pins=5:4 type=non_detented ENC n= 16 sr= 6 pins=7:6 type=non_detented #ainser hardware configuration aINSER n= 1 enabled=1 muxed=1 cs=0 resolution=7bit aINSER n= 2 enabled=0 muxed=1 cs=1 resolution=7bit #Section 1 1 #Encoders EVENT_ENC id= 101 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 1 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 328:100:10 EVENT_ENC id= 102 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 1 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 330:100:10 EVENT_ENC id= 103 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 1 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 332:100:10 EVENT_ENC id= 104 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 1 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 334:100:10 EVENT_ENC id= 105 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 1 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 336:100:10 EVENT_ENC id= 106 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 1 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 338:100:10 EVENT_ENC id= 107 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 1 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 340:100:10 EVENT_ENC id= 108 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 1 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 342:100:10 #Encoders #Section5 EVENT_ENC id= 109 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 1 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 344:100:10 EVENT_ENC id= 110 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 1 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 346:100:10 EVENT_ENC id= 111 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 1 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 348:100:10 EVENT_ENC id= 112 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 1 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 350:100:10 EVENT_ENC id= 113 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 1 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 352:100:10 EVENT_ENC id= 114 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 1 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 354:100:10 EVENT_ENC id= 115 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 1 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 356:100:10 EVENT_ENC id= 116 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 1 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 358:100:10 # BP encodeurs T1 #Section 1 EVENT_BUTTON id= 117 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 1 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 118 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 1 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 119 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 1 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 120 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 1 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 121 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 1 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 122 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 1 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 123 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 1 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 124 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 1 cc= 16 button_mode= Toggle hsv= 0:100:10 # BP encodeurs T2 #Section5 EVENT_BUTTON id= 125 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 1 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 126 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 1 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 127 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 1 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 128 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 1 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 129 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 1 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 130 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 1 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 131 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 1 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 132 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 1 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER #Section 1 EVENT_AINSER id= 133 hw_id= 1 type=CC chn= 1 cc= 17 range= 0:127 EVENT_AINSER id= 134 hw_id= 2 type=CC chn= 1 cc= 18 range= 0:127 EVENT_AINSER id= 135 hw_id= 3 type=CC chn= 1 cc= 19 range= 0:127 EVENT_AINSER id= 136 hw_id= 4 type=CC chn= 1 cc= 20 range= 0:127 #FADER #Section5 EVENT_AINSER id= 137 hw_id= 5 type=CC chn= 1 cc= 17 range= 0:127 EVENT_AINSER id= 138 hw_id= 6 type=CC chn= 1 cc= 18 range= 0:127 EVENT_AINSER id= 139 hw_id= 7 type=CC chn= 1 cc= 19 range= 0:127 EVENT_AINSER id= 140 hw_id= 8 type=CC chn= 1 cc= 20 range= 0:127 #switch #Section 1 EVENT_BUTTON id= 141 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 1 cc= 21 button_mode= Toggle hsv= 328:100:10 EVENT_BUTTON id= 142 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 1 cc= 22 button_mode= Toggle hsv= 330:100:10 EVENT_BUTTON id= 143 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 1 cc= 23 button_mode= Toggle hsv= 332:100:10 EVENT_BUTTON id= 144 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 1 cc= 24 button_mode= Toggle hsv= 334:100:10 #switch #Section5 EVENT_BUTTON id= 153 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 1 cc= 21 button_mode= Toggle hsv= 328:100:10 EVENT_BUTTON id= 154 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 1 cc= 22 button_mode= Toggle hsv= 330:100:10 EVENT_BUTTON id= 155 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 1 cc= 23 button_mode= Toggle hsv= 332:100:10 EVENT_BUTTON id= 156 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 1 cc= 24 button_mode= Toggle hsv= 334:100:10 #POTARD T1 #Section 1 EVENT_AINSER id= 157 hw_id= 9 type=CC chn= 1 cc= 25 range= 0:127 EVENT_AINSER id= 158 hw_id= 10 type=CC chn= 1 cc= 26 range= 0:127 EVENT_AINSER id= 159 hw_id= 11 type=CC chn= 1 cc= 27 range= 0:127 EVENT_AINSER id= 160 hw_id= 12 type=CC chn= 1 cc= 28 range= 0:127 EVENT_AINSER id= 161 hw_id= 13 type=CC chn= 1 cc= 29 range= 0:127 EVENT_AINSER id= 162 hw_id= 14 type=CC chn= 1 cc= 30 range= 0:127 EVENT_AINSER id= 163 hw_id= 15 type=CC chn= 1 cc= 31 range= 0:127 EVENT_AINSER id= 164 hw_id= 16 type=CC chn= 1 cc= 32 range= 0:127 #POTARD T2 #Section5 EVENT_AINSER id= 165 hw_id= 17 type=CC chn= 1 cc= 25 range= 0:127 EVENT_AINSER id= 166 hw_id= 18 type=CC chn= 1 cc= 26 range= 0:127 EVENT_AINSER id= 167 hw_id= 19 type=CC chn= 1 cc= 27 range= 0:127 EVENT_AINSER id= 168 hw_id= 20 type=CC chn= 1 cc= 28 range= 0:127 EVENT_AINSER id= 169 hw_id= 21 type=CC chn= 1 cc= 29 range= 0:127 EVENT_AINSER id= 170 hw_id= 22 type=CC chn= 1 cc= 30 range= 0:127 EVENT_AINSER id= 171 hw_id= 23 type=CC chn= 1 cc= 31 range= 0:127 EVENT_AINSER id= 172 hw_id= 24 type=CC chn= 1 cc= 32 range= 0:127 # SECTION 2 2 #Encoders # SECTION 2 EVENT_ENC id= 201 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 2 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 160:100:10 EVENT_ENC id= 202 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 2 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 170:100:10 EVENT_ENC id= 203 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 2 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 180:100:10 EVENT_ENC id= 204 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 2 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 190:100:10 EVENT_ENC id= 205 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 2 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 200:100:10 EVENT_ENC id= 206 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 2 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 210:100:10 EVENT_ENC id= 207 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 2 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 220:100:10 EVENT_ENC id= 208 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 2 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 230:100:10 # SECTION 6 EVENT_ENC id= 209 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 2 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 160:100:10 EVENT_ENC id= 210 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 2 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 170:100:10 EVENT_ENC id= 211 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 2 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 180:100:10 EVENT_ENC id= 212 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 2 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 190:100:10 EVENT_ENC id= 213 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 2 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 200:100:10 EVENT_ENC id= 214 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 2 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 210:100:10 EVENT_ENC id= 215 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 2 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 220:100:10 EVENT_ENC id= 216 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 2 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 230:100:10 #bouton_poussoir_encodeurs_1 # SECTION 2 EVENT_BUTTON id= 217 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 2 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 218 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 2 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 219 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 2 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 220 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 2 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 221 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 2 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 222 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 2 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 223 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 2 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 224 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 2 cc= 16 button_mode= Toggle hsv= 0:100:10 #bouton_poussoir_encodeurs_2 # SECTION 6 EVENT_BUTTON id= 225 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 2 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 226 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 2 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 227 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 2 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 228 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 2 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 229 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 2 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 230 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 2 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 231 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 2 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 232 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 2 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER # SECTION 2 EVENT_AINSER id= 233 hw_id= 1 type=CC chn= 2 cc= 17 range= 0:127 EVENT_AINSER id= 234 hw_id= 2 type=CC chn= 2 cc= 18 range= 0:127 EVENT_AINSER id= 235 hw_id= 3 type=CC chn= 2 cc= 19 range= 0:127 EVENT_AINSER id= 236 hw_id= 4 type=CC chn= 2 cc= 20 range= 0:127 # SECTION 6 EVENT_AINSER id= 237 hw_id= 5 type=CC chn= 2 cc= 17 range= 0:127 EVENT_AINSER id= 238 hw_id= 6 type=CC chn= 2 cc= 18 range= 0:127 EVENT_AINSER id= 239 hw_id= 7 type=CC chn= 2 cc= 19 range= 0:127 EVENT_AINSER id= 240 hw_id= 8 type=CC chn= 2 cc= 20 range= 0:127 #switch # SECTION 2 EVENT_BUTTON id= 241 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 2 cc= 21 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 242 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 2 cc= 22 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 243 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 2 cc= 23 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 244 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 2 cc= 24 button_mode= Toggle hsv= 220:100:10 #switch # SECTION 6 EVENT_BUTTON id= 253 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 2 cc= 21 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 254 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 2 cc= 22 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 255 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 2 cc= 23 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 256 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 2 cc= 24 button_mode= Toggle hsv= 220:100:10 #POTARD # SECTION 2 EVENT_AINSER id= 257 hw_id= 9 type=CC chn= 2 cc= 25 range= 0:127 EVENT_AINSER id= 258 hw_id= 10 type=CC chn= 2 cc= 26 range= 0:127 EVENT_AINSER id= 259 hw_id= 11 type=CC chn= 2 cc= 27 range= 0:127 EVENT_AINSER id= 260 hw_id= 12 type=CC chn= 2 cc= 28 range= 0:127 EVENT_AINSER id= 261 hw_id= 13 type=CC chn= 2 cc= 29 range= 0:127 EVENT_AINSER id= 262 hw_id= 14 type=CC chn= 2 cc= 30 range= 0:127 EVENT_AINSER id= 263 hw_id= 15 type=CC chn= 2 cc= 31 range= 0:127 EVENT_AINSER id= 264 hw_id= 16 type=CC chn= 2 cc= 32 range= 0:127 #POTARD # SECTION 6 EVENT_AINSER id= 265 hw_id= 17 type=CC chn= 2 cc= 25 range= 0:127 EVENT_AINSER id= 266 hw_id= 18 type=CC chn= 2 cc= 26 range= 0:127 EVENT_AINSER id= 267 hw_id= 19 type=CC chn= 2 cc= 27 range= 0:127 EVENT_AINSER id= 268 hw_id= 20 type=CC chn= 2 cc= 28 range= 0:127 EVENT_AINSER id= 269 hw_id= 21 type=CC chn= 2 cc= 29 range= 0:127 EVENT_AINSER id= 270 hw_id= 22 type=CC chn= 2 cc= 30 range= 0:127 EVENT_AINSER id= 271 hw_id= 23 type=CC chn= 2 cc= 31 range= 0:127 EVENT_AINSER id= 272 hw_id= 24 type=CC chn= 2 cc= 32 range= 0:127 #Section 3 3 #Encoders EVENT_ENC id= 301 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 3 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 302 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 3 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 303 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 3 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 304 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 3 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 305 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 3 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 306 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 3 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 307 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 3 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 308 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 3 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 #Encoders #Section 7 EVENT_ENC id= 309 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 3 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 310 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 3 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 311 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 3 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 312 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 3 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 313 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 3 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 314 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 3 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 315 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 3 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 316 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 3 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 # BP encodeurs T1 #Section 3 EVENT_BUTTON id= 317 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 3 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 318 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 3 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 319 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 3 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 320 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 3 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 321 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 3 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 322 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 3 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 323 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 3 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 324 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 3 cc= 16 button_mode= Toggle hsv= 0:100:10 # BP encodeurs T2 #Section 7 EVENT_BUTTON id= 325 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 3 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 326 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 3 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 327 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 3 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 328 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 3 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 329 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 3 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 330 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 3 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 331 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 3 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 332 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 3 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER #Section 3 EVENT_AINSER id= 333 hw_id= 1 type=CC chn= 3 cc= 17 range= 0:127 EVENT_AINSER id= 334 hw_id= 2 type=CC chn= 3 cc= 18 range= 0:127 EVENT_AINSER id= 335 hw_id= 3 type=CC chn= 3 cc= 19 range= 0:127 EVENT_AINSER id= 336 hw_id= 4 type=CC chn= 3 cc= 20 range= 0:127 #FADER #Section 7 EVENT_AINSER id= 337 hw_id= 5 type=CC chn= 3 cc= 17 range= 0:127 EVENT_AINSER id= 338 hw_id= 6 type=CC chn= 3 cc= 18 range= 0:127 EVENT_AINSER id= 339 hw_id= 7 type=CC chn= 3 cc= 19 range= 0:127 EVENT_AINSER id= 340 hw_id= 8 type=CC chn= 3 cc= 20 range= 0:127 #switch #Section 3 EVENT_BUTTON id= 341 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 3 cc= 21 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 342 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 3 cc= 22 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 343 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 3 cc= 23 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 344 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 3 cc= 24 button_mode= Toggle hsv= 100:100:10 #switch #Section 7 EVENT_BUTTON id= 353 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 3 cc= 21 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 354 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 3 cc= 22 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 355 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 3 cc= 23 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 356 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 3 cc= 24 button_mode= Toggle hsv= 100:100:10 #POTARD T1 #Section 3 EVENT_AINSER id= 357 hw_id= 9 type=CC chn= 3 cc= 25 range= 0:127 EVENT_AINSER id= 358 hw_id= 10 type=CC chn= 3 cc= 26 range= 0:127 EVENT_AINSER id= 359 hw_id= 11 type=CC chn= 3 cc= 27 range= 0:127 EVENT_AINSER id= 360 hw_id= 12 type=CC chn= 3 cc= 28 range= 0:127 EVENT_AINSER id= 361 hw_id= 13 type=CC chn= 3 cc= 29 range= 0:127 EVENT_AINSER id= 362 hw_id= 14 type=CC chn= 3 cc= 30 range= 0:127 EVENT_AINSER id= 363 hw_id= 15 type=CC chn= 3 cc= 31 range= 0:127 EVENT_AINSER id= 364 hw_id= 16 type=CC chn= 3 cc= 32 range= 0:127 #POTARD T2 #Section 7 EVENT_AINSER id= 365 hw_id= 17 type=CC chn= 3 cc= 25 range= 0:127 EVENT_AINSER id= 366 hw_id= 18 type=CC chn= 3 cc= 26 range= 0:127 EVENT_AINSER id= 367 hw_id= 19 type=CC chn= 3 cc= 27 range= 0:127 EVENT_AINSER id= 368 hw_id= 20 type=CC chn= 3 cc= 28 range= 0:127 EVENT_AINSER id= 369 hw_id= 21 type=CC chn= 3 cc= 29 range= 0:127 EVENT_AINSER id= 370 hw_id= 22 type=CC chn= 3 cc= 30 range= 0:127 EVENT_AINSER id= 371 hw_id= 23 type=CC chn= 3 cc= 31 range= 0:127 EVENT_AINSER id= 372 hw_id= 24 type=CC chn= 3 cc= 32 range= 0:127 # SECTION 4 4 #Encoders # SECTION 4 EVENT_ENC id= 401 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 4 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 402 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 4 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 403 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 4 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 404 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 4 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 405 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 4 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 406 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 4 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 407 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 4 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 408 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 4 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 # SECTION 8 EVENT_ENC id= 409 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 4 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 410 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 4 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 411 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 4 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 412 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 4 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 413 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 4 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 414 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 4 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 415 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 4 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 416 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 4 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 #bouton_poussoir_encodeurs_1 # SECTION 4 EVENT_BUTTON id= 417 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 4 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 418 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 4 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 419 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 4 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 420 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 4 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 421 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 4 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 422 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 4 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 423 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 4 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 424 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 4 cc= 16 button_mode= Toggle hsv= 0:100:10 #bouton_poussoir_encodeurs_2 # SECTION 8 EVENT_BUTTON id= 425 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 4 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 426 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 4 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 427 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 4 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 428 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 4 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 429 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 4 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 430 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 4 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 431 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 4 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 432 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 4 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER # SECTION 4 EVENT_AINSER id= 433 hw_id= 1 type=CC chn= 4 cc= 17 range= 0:127 EVENT_AINSER id= 434 hw_id= 2 type=CC chn= 4 cc= 18 range= 0:127 EVENT_AINSER id= 435 hw_id= 3 type=CC chn= 4 cc= 19 range= 0:127 EVENT_AINSER id= 436 hw_id= 4 type=CC chn= 4 cc= 20 range= 0:127 # SECTION 8 EVENT_AINSER id= 437 hw_id= 5 type=CC chn= 4 cc= 17 range= 0:127 EVENT_AINSER id= 438 hw_id= 6 type=CC chn= 4 cc= 18 range= 0:127 EVENT_AINSER id= 439 hw_id= 7 type=CC chn= 4 cc= 19 range= 0:127 EVENT_AINSER id= 440 hw_id= 8 type=CC chn= 4 cc= 20 range= 0:127 #switch # SECTION 4 EVENT_BUTTON id= 441 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 4 cc= 21 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 442 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 4 cc= 22 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 443 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 4 cc= 23 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 444 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 4 cc= 24 button_mode= Toggle hsv= 50:100:10 #switch # SECTION 8 EVENT_BUTTON id= 453 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 4 cc= 21 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 454 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 4 cc= 22 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 455 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 4 cc= 23 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 456 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 4 cc= 24 button_mode= Toggle hsv= 50:100:10 #POTARD # SECTION 4 EVENT_AINSER id= 457 hw_id= 9 type=CC chn= 4 cc= 25 range= 0:127 EVENT_AINSER id= 458 hw_id= 10 type=CC chn= 4 cc= 26 range= 0:127 EVENT_AINSER id= 459 hw_id= 11 type=CC chn= 4 cc= 27 range= 0:127 EVENT_AINSER id= 460 hw_id= 12 type=CC chn= 4 cc= 28 range= 0:127 EVENT_AINSER id= 461 hw_id= 13 type=CC chn= 4 cc= 29 range= 0:127 EVENT_AINSER id= 462 hw_id= 14 type=CC chn= 4 cc= 30 range= 0:127 EVENT_AINSER id= 463 hw_id= 15 type=CC chn= 4 cc= 31 range= 0:127 EVENT_AINSER id= 464 hw_id= 16 type=CC chn= 4 cc= 32 range= 0:127 #POTARD # SECTION 8 EVENT_AINSER id= 465 hw_id= 17 type=CC chn= 4 cc= 25 range= 0:127 EVENT_AINSER id= 466 hw_id= 18 type=CC chn= 4 cc= 26 range= 0:127 EVENT_AINSER id= 467 hw_id= 19 type=CC chn= 4 cc= 27 range= 0:127 EVENT_AINSER id= 468 hw_id= 20 type=CC chn= 4 cc= 28 range= 0:127 EVENT_AINSER id= 469 hw_id= 21 type=CC chn= 4 cc= 29 range= 0:127 EVENT_AINSER id= 470 hw_id= 22 type=CC chn= 4 cc= 30 range= 0:127 EVENT_AINSER id= 471 hw_id= 23 type=CC chn= 4 cc= 31 range= 0:127 EVENT_AINSER id= 472 hw_id= 24 type=CC chn= 4 cc= 32 range= 0:127 Quote # NGR if ^section == 0 log "Hello World!" # exec_meta RgbLedRainbow:5:10 delay_ms 2000 exit endif ################################################################################# if ^section == 1 log "Section is 1" set_hsv RGBLED:261 300:100:10 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:1 # Active # Encoders set_active (id)ENC:101 1 set_active (id)ENC:102 1 set_active (id)ENC:103 1 set_active (id)ENC:104 1 set_active (id)ENC:105 1 set_active (id)ENC:106 1 set_active (id)ENC:107 1 set_active (id)ENC:108 1 # BP ENC set_active (id)BUTTON:117 1 set_active (id)BUTTON:118 1 set_active (id)BUTTON:119 1 set_active (id)BUTTON:120 1 set_active (id)BUTTON:121 1 set_active (id)BUTTON:122 1 set_active (id)BUTTON:123 1 set_active (id)BUTTON:124 1 #FADERS set_active (id)AINSER:133 1 set_active (id)AINSER:134 1 set_active (id)AINSER:135 1 set_active (id)AINSER:136 1 #SWICTH MIXER set_active (id)BUTTON:141 1 set_active (id)BUTTON:142 1 set_active (id)BUTTON:143 1 set_active (id)BUTTON:144 1 #POTARDS set_active (id)AINSER:157 1 set_active (id)AINSER:158 1 set_active (id)AINSER:159 1 set_active (id)AINSER:160 1 set_active (id)AINSER:161 1 set_active (id)AINSER:162 1 set_active (id)AINSER:163 1 set_active (id)AINSER:164 1 # Desative #ENC set_active (id)ENC:201 0 set_active (id)ENC:202 0 set_active (id)ENC:203 0 set_active (id)ENC:204 0 set_active (id)ENC:205 0 set_active (id)ENC:206 0 set_active (id)ENC:207 0 set_active (id)ENC:208 0 # BP ENC set_active (id)BUTTON:217 0 set_active (id)BUTTON:218 0 set_active (id)BUTTON:219 0 set_active (id)BUTTON:220 0 set_active (id)BUTTON:221 0 set_active (id)BUTTON:222 0 set_active (id)BUTTON:223 0 set_active (id)BUTTON:224 0 #FADERS set_active (id)AINSER:233 0 set_active (id)AINSER:234 0 set_active (id)AINSER:235 0 set_active (id)AINSER:236 0 #SWICTH MIXER set_active (id)BUTTON:241 0 set_active (id)BUTTON:242 0 set_active (id)BUTTON:243 0 set_active (id)BUTTON:244 0 #POTARDS set_active (id)AINSER:257 0 set_active (id)AINSER:258 0 set_active (id)AINSER:259 0 set_active (id)AINSER:260 0 set_active (id)AINSER:261 0 set_active (id)AINSER:262 0 set_active (id)AINSER:263 0 set_active (id)AINSER:264 0 #ENC set_active (id)ENC:301 0 set_active (id)ENC:302 0 set_active (id)ENC:303 0 set_active (id)ENC:304 0 set_active (id)ENC:305 0 set_active (id)ENC:306 0 set_active (id)ENC:307 0 set_active (id)ENC:308 0 # BP ENC set_active (id)BUTTON:317 0 set_active (id)BUTTON:318 0 set_active (id)BUTTON:319 0 set_active (id)BUTTON:320 0 set_active (id)BUTTON:321 0 set_active (id)BUTTON:322 0 set_active (id)BUTTON:323 0 set_active (id)BUTTON:324 0 #FADERS set_active (id)AINSER:333 0 set_active (id)AINSER:334 0 set_active (id)AINSER:335 0 set_active (id)AINSER:336 0 #SWICTH MIXER set_active (id)BUTTON:341 0 set_active (id)BUTTON:342 0 set_active (id)BUTTON:343 0 set_active (id)BUTTON:344 0 #POTARDS set_active (id)AINSER:357 0 set_active (id)AINSER:358 0 set_active (id)AINSER:359 0 set_active (id)AINSER:360 0 set_active (id)AINSER:361 0 set_active (id)AINSER:362 0 set_active (id)AINSER:363 0 set_active (id)AINSER:364 0 #ENC set_active (id)ENC:401 0 set_active (id)ENC:402 0 set_active (id)ENC:403 0 set_active (id)ENC:404 0 set_active (id)ENC:405 0 set_active (id)ENC:406 0 set_active (id)ENC:407 0 set_active (id)ENC:408 0 # BP ENC set_active (id)BUTTON:417 0 set_active (id)BUTTON:418 0 set_active (id)BUTTON:419 0 set_active (id)BUTTON:420 0 set_active (id)BUTTON:421 0 set_active (id)BUTTON:422 0 set_active (id)BUTTON:423 0 set_active (id)BUTTON:424 0 #FADERS set_active (id)AINSER:433 0 set_active (id)AINSER:434 0 set_active (id)AINSER:435 0 set_active (id)AINSER:436 0 #SWICTH MIXER set_active (id)BUTTON:441 0 set_active (id)BUTTON:442 0 set_active (id)BUTTON:443 0 set_active (id)BUTTON:444 0 #POTARDS set_active (id)AINSER:457 0 set_active (id)AINSER:458 0 set_active (id)AINSER:459 0 set_active (id)AINSER:460 0 set_active (id)AINSER:461 0 set_active (id)AINSER:462 0 set_active (id)AINSER:463 0 set_active (id)AINSER:464 0 exit endif if ^section == 2 log "Section is 2 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:10 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:1 # Active # Encoders set_active (id)ENC:101 0 set_active (id)ENC:102 0 set_active (id)ENC:103 0 set_active (id)ENC:104 0 set_active (id)ENC:105 0 set_active (id)ENC:106 0 set_active (id)ENC:107 0 set_active (id)ENC:108 0 # BP ENC set_active (id)BUTTON:117 0 set_active (id)BUTTON:118 0 set_active (id)BUTTON:119 0 set_active (id)BUTTON:120 0 set_active (id)BUTTON:121 0 set_active (id)BUTTON:122 0 set_active (id)BUTTON:123 0 set_active (id)BUTTON:124 0 #FADERS set_active (id)AINSER:133 0 set_active (id)AINSER:134 0 set_active (id)AINSER:135 0 set_active (id)AINSER:136 0 #SWICTH MIXER set_active (id)BUTTON:141 0 set_active (id)BUTTON:142 0 set_active (id)BUTTON:143 0 set_active (id)BUTTON:144 0 #POTARDS 0 set_active (id)AINSER:157 0 set_active (id)AINSER:158 0 set_active (id)AINSER:159 0 set_active (id)AINSER:160 0 set_active (id)AINSER:161 0 set_active (id)AINSER:162 0 set_active (id)AINSER:163 0 set_active (id)AINSER:164 0 # Desative #ENC set_active (id)ENC:201 1 set_active (id)ENC:202 1 set_active (id)ENC:203 1 set_active (id)ENC:204 1 set_active (id)ENC:205 1 set_active (id)ENC:206 1 set_active (id)ENC:207 1 set_active (id)ENC:208 1 # BP ENC set_active (id)BUTTON:217 1 set_active (id)BUTTON:218 1 set_active (id)BUTTON:219 1 set_active (id)BUTTON:220 1 set_active (id)BUTTON:221 1 set_active (id)BUTTON:222 1 set_active (id)BUTTON:223 1 set_active (id)BUTTON:224 1 #FADERS set_active (id)AINSER:233 1 set_active (id)AINSER:234 1 set_active (id)AINSER:235 1 set_active (id)AINSER:236 1 #SWICTH MIXER set_active (id)BUTTON:241 1 set_active (id)BUTTON:242 1 set_active (id)BUTTON:243 1 set_active (id)BUTTON:244 1 #POTARDS set_active (id)AINSER:257 1 set_active (id)AINSER:258 1 set_active (id)AINSER:259 1 set_active (id)AINSER:260 1 set_active (id)AINSER:261 1 set_active (id)AINSER:262 1 set_active (id)AINSER:263 1 set_active (id)AINSER:264 1 #ENC set_active (id)ENC:301 0 set_active (id)ENC:302 0 set_active (id)ENC:303 0 set_active (id)ENC:304 0 set_active (id)ENC:305 0 set_active (id)ENC:306 0 set_active (id)ENC:307 0 set_active (id)ENC:308 0 # BP ENC set_active (id)BUTTON:317 0 set_active (id)BUTTON:318 0 set_active (id)BUTTON:319 0 set_active (id)BUTTON:320 0 set_active (id)BUTTON:321 0 set_active (id)BUTTON:322 0 set_active (id)BUTTON:323 0 set_active (id)BUTTON:324 0 #FADERS set_active (id)AINSER:333 0 set_active (id)AINSER:334 0 set_active (id)AINSER:335 0 set_active (id)AINSER:336 0 #SWICTH MIXER set_active (id)BUTTON:341 0 set_active (id)BUTTON:342 0 set_active (id)BUTTON:343 0 set_active (id)BUTTON:344 0 #POTARDS set_active (id)AINSER:357 0 set_active (id)AINSER:358 0 set_active (id)AINSER:359 0 set_active (id)AINSER:360 0 set_active (id)AINSER:361 0 set_active (id)AINSER:362 0 set_active (id)AINSER:363 0 set_active (id)AINSER:364 0 #ENC set_active (id)ENC:401 0 set_active (id)ENC:402 0 set_active (id)ENC:403 0 set_active (id)ENC:404 0 set_active (id)ENC:405 0 set_active (id)ENC:406 0 set_active (id)ENC:407 0 set_active (id)ENC:408 0 # BP ENC set_active (id)BUTTON:417 0 set_active (id)BUTTON:418 0 set_active (id)BUTTON:419 0 set_active (id)BUTTON:420 0 set_active (id)BUTTON:421 0 set_active (id)BUTTON:422 0 set_active (id)BUTTON:423 0 set_active (id)BUTTON:424 0 #FADERS set_active (id)AINSER:433 0 set_active (id)AINSER:434 0 set_active (id)AINSER:435 0 set_active (id)AINSER:436 0 #SWICTH MIXER set_active (id)BUTTON:441 0 set_active (id)BUTTON:442 0 set_active (id)BUTTON:443 0 set_active (id)BUTTON:444 0 #POTARDS set_active (id)AINSER:457 0 set_active (id)AINSER:458 0 set_active (id)AINSER:459 0 set_active (id)AINSER:460 0 set_active (id)AINSER:461 0 set_active (id)AINSER:462 0 set_active (id)AINSER:463 0 set_active (id)AINSER:464 0 exit endif if ^section == 3 log "Section is 3 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:10 set_hsv RGBLED:264 50:100:1 # Active # Encoders set_active (id)ENC:101 0 set_active (id)ENC:102 0 set_active (id)ENC:103 0 set_active (id)ENC:104 0 set_active (id)ENC:105 0 set_active (id)ENC:106 0 set_active (id)ENC:107 0 set_active (id)ENC:108 0 # BP ENC set_active (id)BUTTON:117 0 set_active (id)BUTTON:118 0 set_active (id)BUTTON:119 0 set_active (id)BUTTON:120 0 set_active (id)BUTTON:121 0 set_active (id)BUTTON:122 0 set_active (id)BUTTON:123 0 set_active (id)BUTTON:124 0 #FADERS set_active (id)AINSER:133 0 set_active (id)AINSER:134 0 set_active (id)AINSER:135 0 set_active (id)AINSER:136 0 #SWICTH MIXER set_active (id)BUTTON:141 0 set_active (id)BUTTON:142 0 set_active (id)BUTTON:143 0 set_active (id)BUTTON:144 0 #POTARDS set_active (id)AINSER:157 0 set_active (id)AINSER:158 0 set_active (id)AINSER:159 0 set_active (id)AINSER:160 0 set_active (id)AINSER:161 0 set_active (id)AINSER:162 0 set_active (id)AINSER:163 0 set_active (id)AINSER:164 0 # Desative #ENC set_active (id)ENC:201 0 set_active (id)ENC:202 0 set_active (id)ENC:203 0 set_active (id)ENC:204 0 set_active (id)ENC:205 0 set_active (id)ENC:206 0 set_active (id)ENC:207 0 set_active (id)ENC:208 0 # BP ENC set_active (id)BUTTON:217 0 set_active (id)BUTTON:218 0 set_active (id)BUTTON:219 0 set_active (id)BUTTON:220 0 set_active (id)BUTTON:221 0 set_active (id)BUTTON:222 0 set_active (id)BUTTON:223 0 set_active (id)BUTTON:224 0 #FADERS set_active (id)AINSER:233 0 set_active (id)AINSER:234 0 set_active (id)AINSER:235 0 set_active (id)AINSER:236 0 #SWICTH MIXER set_active (id)BUTTON:241 0 set_active (id)BUTTON:242 0 set_active (id)BUTTON:243 0 set_active (id)BUTTON:244 0 #POTARDS set_active (id)AINSER:257 0 set_active (id)AINSER:258 0 set_active (id)AINSER:259 0 set_active (id)AINSER:260 0 set_active (id)AINSER:261 0 set_active (id)AINSER:262 0 set_active (id)AINSER:263 0 set_active (id)AINSER:264 0 #ENC set_active (id)ENC:301 1 set_active (id)ENC:302 1 set_active (id)ENC:303 1 set_active (id)ENC:304 1 set_active (id)ENC:305 1 set_active (id)ENC:306 1 set_active (id)ENC:307 1 set_active (id)ENC:308 1 # BP ENC set_active (id)BUTTON:317 1 set_active (id)BUTTON:318 1 set_active (id)BUTTON:319 1 set_active (id)BUTTON:320 1 set_active (id)BUTTON:321 1 set_active (id)BUTTON:322 1 set_active (id)BUTTON:323 1 set_active (id)BUTTON:324 1 #FADERS set_active (id)AINSER:333 1 set_active (id)AINSER:334 1 set_active (id)AINSER:335 1 set_active (id)AINSER:336 1 #SWICTH MIXER set_active (id)BUTTON:341 1 set_active (id)BUTTON:342 1 set_active (id)BUTTON:343 1 set_active (id)BUTTON:344 1 #POTARDS set_active (id)AINSER:357 1 set_active (id)AINSER:358 1 set_active (id)AINSER:359 1 set_active (id)AINSER:360 1 set_active (id)AINSER:361 1 set_active (id)AINSER:362 1 set_active (id)AINSER:363 1 set_active (id)AINSER:364 1 #ENC set_active (id)ENC:401 0 set_active (id)ENC:402 0 set_active (id)ENC:403 0 set_active (id)ENC:404 0 set_active (id)ENC:405 0 set_active (id)ENC:406 0 set_active (id)ENC:407 0 set_active (id)ENC:408 0 # BP ENC set_active (id)BUTTON:417 0 set_active (id)BUTTON:418 0 set_active (id)BUTTON:419 0 set_active (id)BUTTON:420 0 set_active (id)BUTTON:421 0 set_active (id)BUTTON:422 0 set_active (id)BUTTON:423 0 set_active (id)BUTTON:424 0 #FADERS set_active (id)AINSER:433 0 set_active (id)AINSER:434 0 set_active (id)AINSER:435 0 set_active (id)AINSER:436 0 #SWICTH MIXER set_active (id)BUTTON:441 0 set_active (id)BUTTON:442 0 set_active (id)BUTTON:443 0 set_active (id)BUTTON:444 0 #POTARDS set_active (id)AINSER:457 0 set_active (id)AINSER:458 0 set_active (id)AINSER:459 0 set_active (id)AINSER:460 0 set_active (id)AINSER:461 0 set_active (id)AINSER:462 0 set_active (id)AINSER:463 0 set_active (id)AINSER:464 0 exit endif if ^section == 4 log "Section is 4 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:10 # Active # Encoders set_active (id)ENC:101 0 set_active (id)ENC:102 0 set_active (id)ENC:103 0 set_active (id)ENC:104 0 set_active (id)ENC:105 0 set_active (id)ENC:106 0 set_active (id)ENC:107 0 set_active (id)ENC:108 0 # BP ENC set_active (id)BUTTON:117 0 set_active (id)BUTTON:118 0 set_active (id)BUTTON:119 0 set_active (id)BUTTON:120 0 set_active (id)BUTTON:121 0 set_active (id)BUTTON:122 0 set_active (id)BUTTON:123 0 set_active (id)BUTTON:124 0 #FADERS set_active (id)AINSER:133 0 set_active (id)AINSER:134 0 set_active (id)AINSER:135 0 set_active (id)AINSER:136 0 #SWICTH MIXER set_active (id)BUTTON:141 0 set_active (id)BUTTON:142 0 set_active (id)BUTTON:143 0 set_active (id)BUTTON:144 0 #POTARDS 0 set_active (id)AINSER:157 0 set_active (id)AINSER:158 0 set_active (id)AINSER:159 0 set_active (id)AINSER:160 0 set_active (id)AINSER:161 0 set_active (id)AINSER:162 0 set_active (id)AINSER:163 0 set_active (id)AINSER:164 0 # Desative #ENC set_active (id)ENC:201 0 set_active (id)ENC:202 0 set_active (id)ENC:203 0 set_active (id)ENC:204 0 set_active (id)ENC:205 0 set_active (id)ENC:206 0 set_active (id)ENC:207 0 set_active (id)ENC:208 0 # BP ENC set_active (id)BUTTON:217 0 set_active (id)BUTTON:218 0 set_active (id)BUTTON:219 0 set_active (id)BUTTON:220 0 set_active (id)BUTTON:221 0 set_active (id)BUTTON:222 0 set_active (id)BUTTON:223 0 set_active (id)BUTTON:224 0 #FADERS set_active (id)AINSER:233 0 set_active (id)AINSER:234 0 set_active (id)AINSER:235 0 set_active (id)AINSER:236 0 #SWICTH MIXER set_active (id)BUTTON:241 0 set_active (id)BUTTON:242 0 set_active (id)BUTTON:243 0 set_active (id)BUTTON:244 0 #POTARDS set_active (id)AINSER:257 0 set_active (id)AINSER:258 0 set_active (id)AINSER:259 0 set_active (id)AINSER:260 0 set_active (id)AINSER:261 0 set_active (id)AINSER:262 0 set_active (id)AINSER:263 0 set_active (id)AINSER:264 0 #ENC set_active (id)ENC:301 0 set_active (id)ENC:302 0 set_active (id)ENC:303 0 set_active (id)ENC:304 0 set_active (id)ENC:305 0 set_active (id)ENC:306 0 set_active (id)ENC:307 0 set_active (id)ENC:308 0 # BP ENC set_active (id)BUTTON:317 0 set_active (id)BUTTON:318 0 set_active (id)BUTTON:319 0 set_active (id)BUTTON:320 0 set_active (id)BUTTON:321 0 set_active (id)BUTTON:322 0 set_active (id)BUTTON:323 0 set_active (id)BUTTON:324 0 #FADERS set_active (id)AINSER:333 0 set_active (id)AINSER:334 0 set_active (id)AINSER:335 0 set_active (id)AINSER:336 0 #SWICTH MIXER set_active (id)BUTTON:341 0 set_active (id)BUTTON:342 0 set_active (id)BUTTON:343 0 set_active (id)BUTTON:344 0 #POTARDS set_active (id)AINSER:357 0 set_active (id)AINSER:358 0 set_active (id)AINSER:359 0 set_active (id)AINSER:360 0 set_active (id)AINSER:361 0 set_active (id)AINSER:362 0 set_active (id)AINSER:363 0 set_active (id)AINSER:364 0 #ENC set_active (id)ENC:401 1 set_active (id)ENC:402 1 set_active (id)ENC:403 1 set_active (id)ENC:404 1 set_active (id)ENC:405 1 set_active (id)ENC:406 1 set_active (id)ENC:407 1 set_active (id)ENC:408 1 # BP ENC set_active (id)BUTTON:417 1 set_active (id)BUTTON:418 1 set_active (id)BUTTON:419 1 set_active (id)BUTTON:420 1 set_active (id)BUTTON:421 1 set_active (id)BUTTON:422 1 set_active (id)BUTTON:423 1 set_active (id)BUTTON:424 1 #FADERS set_active (id)AINSER:433 1 set_active (id)AINSER:434 1 set_active (id)AINSER:435 1 set_active (id)AINSER:436 1 #SWICTH MIXER set_active (id)BUTTON:441 1 set_active (id)BUTTON:442 1 set_active (id)BUTTON:443 1 set_active (id)BUTTON:444 1 #POTARDS set_active (id)AINSER:457 1 set_active (id)AINSER:458 1 set_active (id)AINSER:459 1 set_active (id)AINSER:460 1 set_active (id)AINSER:461 1 set_active (id)AINSER:462 1 set_active (id)AINSER:463 1 set_active (id)AINSER:464 1 exit endif if ^section == 5 log "Section is 5 " set_hsv RGBLED:269 300:100:10 set_hsv RGBLED:270 200:100:1 set_hsv RGBLED:271 100:100:1 set_hsv RGBLED:272 50:100:1 # Active # Encoders set_active (id)ENC:109 1 set_active (id)ENC:110 1 set_active (id)ENC:111 1 set_active (id)ENC:112 1 set_active (id)ENC:113 1 set_active (id)ENC:114 1 set_active (id)ENC:115 1 set_active (id)ENC:116 1 # BP ENC set_active (id)BUTTON:125 1 set_active (id)BUTTON:126 1 set_active (id)BUTTON:127 1 set_active (id)BUTTON:128 1 set_active (id)BUTTON:129 1 set_active (id)BUTTON:130 1 set_active (id)BUTTON:131 1 set_active (id)BUTTON:132 1 #FADERS set_active (id)AINSER:137 1 set_active (id)AINSER:138 1 set_active (id)AINSER:139 1 set_active (id)AINSER:140 1 #SWICTH MIXER set_active (id)BUTTON:153 1 set_active (id)BUTTON:154 1 set_active (id)BUTTON:155 1 set_active (id)BUTTON:156 1 #POTARDS set_active (id)AINSER:165 1 set_active (id)AINSER:166 1 set_active (id)AINSER:167 1 set_active (id)AINSER:168 1 set_active (id)AINSER:169 1 set_active (id)AINSER:170 1 set_active (id)AINSER:171 1 set_active (id)AINSER:172 1 # Desative #ENC set_active (id)ENC:209 0 set_active (id)ENC:210 0 set_active (id)ENC:211 0 set_active (id)ENC:212 0 set_active (id)ENC:213 0 set_active (id)ENC:214 0 set_active (id)ENC:215 0 set_active (id)ENC:216 0 # BP ENC set_active (id)BUTTON:225 0 set_active (id)BUTTON:226 0 set_active (id)BUTTON:227 0 set_active (id)BUTTON:228 0 set_active (id)BUTTON:229 0 set_active (id)BUTTON:230 0 set_active (id)BUTTON:231 0 set_active (id)BUTTON:232 0 #FADERS set_active (id)AINSER:237 0 set_active (id)AINSER:238 0 set_active (id)AINSER:239 0 set_active (id)AINSER:240 0 #SWICTH MIXER set_active (id)BUTTON:253 0 set_active (id)BUTTON:254 0 set_active (id)BUTTON:255 0 set_active (id)BUTTON:256 0 #POTARDS set_active (id)AINSER:265 0 set_active (id)AINSER:266 0 set_active (id)AINSER:267 0 set_active (id)AINSER:268 0 set_active (id)AINSER:269 0 set_active (id)AINSER:270 0 set_active (id)AINSER:271 0 set_active (id)AINSER:272 0 #ENC set_active (id)ENC:309 0 set_active (id)ENC:310 0 set_active (id)ENC:311 0 set_active (id)ENC:312 0 set_active (id)ENC:313 0 set_active (id)ENC:314 0 set_active (id)ENC:315 0 set_active (id)ENC:316 0 # BP ENC set_active (id)BUTTON:325 0 set_active (id)BUTTON:326 0 set_active (id)BUTTON:327 0 set_active (id)BUTTON:328 0 set_active (id)BUTTON:329 0 set_active (id)BUTTON:330 0 set_active (id)BUTTON:331 0 set_active (id)BUTTON:332 0 #FADERS set_active (id)AINSER:337 0 set_active (id)AINSER:338 0 set_active (id)AINSER:339 0 set_active (id)AINSER:340 0 #SWICTH MIXER set_active (id)BUTTON:353 0 set_active (id)BUTTON:354 0 set_active (id)BUTTON:355 0 set_active (id)BUTTON:356 0 #POTARDS set_active (id)AINSER:365 0 set_active (id)AINSER:366 0 set_active (id)AINSER:367 0 set_active (id)AINSER:368 0 set_active (id)AINSER:369 0 set_active (id)AINSER:370 0 set_active (id)AINSER:371 0 set_active (id)AINSER:372 0 #ENC set_active (id)ENC:409 0 set_active (id)ENC:410 0 set_active (id)ENC:411 0 set_active (id)ENC:412 0 set_active (id)ENC:413 0 set_active (id)ENC:414 0 set_active (id)ENC:415 0 set_active (id)ENC:416 0 # BP ENC set_active (id)BUTTON:425 0 set_active (id)BUTTON:426 0 set_active (id)BUTTON:427 0 set_active (id)BUTTON:428 0 set_active (id)BUTTON:429 0 set_active (id)BUTTON:430 0 set_active (id)BUTTON:431 0 set_active (id)BUTTON:432 0 #FADERS set_active (id)AINSER:437 0 set_active (id)AINSER:438 0 set_active (id)AINSER:439 0 set_active (id)AINSER:440 0 #SWICTH MIXER set_active (id)BUTTON:453 0 set_active (id)BUTTON:454 0 set_active (id)BUTTON:455 0 set_active (id)BUTTON:456 0 #POTARDS set_active (id)AINSER:465 0 set_active (id)AINSER:466 0 set_active (id)AINSER:467 0 set_active (id)AINSER:468 0 set_active (id)AINSER:469 0 set_active (id)AINSER:470 0 set_active (id)AINSER:471 0 set_active (id)AINSER:472 0 exit endif if ^section == 6 log "Section is 6 " set_hsv RGBLED:269 300:100:1 set_hsv RGBLED:270 200:100:10 set_hsv RGBLED:271 100:100:1 set_hsv RGBLED:272 50:100:1 # Active # Encoders set_active (id)ENC:109 0 set_active (id)ENC:110 0 set_active (id)ENC:111 0 set_active (id)ENC:112 0 set_active (id)ENC:113 0 set_active (id)ENC:114 0 set_active (id)ENC:115 0 set_active (id)ENC:116 0 # BP ENC set_active (id)BUTTON:125 0 set_active (id)BUTTON:126 0 set_active (id)BUTTON:127 0 set_active (id)BUTTON:128 0 set_active (id)BUTTON:129 0 set_active (id)BUTTON:130 0 set_active (id)BUTTON:131 0 set_active (id)BUTTON:132 0 #FADERS set_active (id)AINSER:137 0 set_active (id)AINSER:138 0 set_active (id)AINSER:139 0 set_active (id)AINSER:140 0 #SWICTH MIXER set_active (id)BUTTON:153 0 set_active (id)BUTTON:154 0 set_active (id)BUTTON:155 0 set_active (id)BUTTON:156 0 #POTARDS set_active (id)AINSER:165 0 set_active (id)AINSER:166 0 set_active (id)AINSER:167 0 set_active (id)AINSER:168 0 set_active (id)AINSER:169 0 set_active (id)AINSER:170 0 set_active (id)AINSER:171 0 set_active (id)AINSER:172 0 # Desative #ENC set_active (id)ENC:209 1 set_active (id)ENC:210 1 set_active (id)ENC:211 1 set_active (id)ENC:212 1 set_active (id)ENC:213 1 set_active (id)ENC:214 1 set_active (id)ENC:215 1 set_active (id)ENC:216 1 # BP ENC set_active (id)BUTTON:225 1 set_active (id)BUTTON:226 1 set_active (id)BUTTON:227 1 set_active (id)BUTTON:228 1 set_active (id)BUTTON:229 1 set_active (id)BUTTON:230 1 set_active (id)BUTTON:231 1 set_active (id)BUTTON:232 1 #FADERS set_active (id)AINSER:237 1 set_active (id)AINSER:238 1 set_active (id)AINSER:239 1 set_active (id)AINSER:240 1 #SWICTH MIXER set_active (id)BUTTON:253 1 set_active (id)BUTTON:254 1 set_active (id)BUTTON:255 1 set_active (id)BUTTON:256 1 #POTARDS set_active (id)AINSER:265 1 set_active (id)AINSER:266 1 set_active (id)AINSER:267 1 set_active (id)AINSER:268 1 set_active (id)AINSER:269 1 set_active (id)AINSER:270 1 set_active (id)AINSER:271 1 set_active (id)AINSER:272 1 #ENC set_active (id)ENC:309 0 set_active (id)ENC:310 0 set_active (id)ENC:311 0 set_active (id)ENC:312 0 set_active (id)ENC:313 0 set_active (id)ENC:314 0 set_active (id)ENC:315 0 set_active (id)ENC:316 0 # BP ENC set_active (id)BUTTON:325 0 set_active (id)BUTTON:326 0 set_active (id)BUTTON:327 0 set_active (id)BUTTON:328 0 set_active (id)BUTTON:329 0 set_active (id)BUTTON:330 0 set_active (id)BUTTON:331 0 set_active (id)BUTTON:332 0 #FADERS set_active (id)AINSER:337 0 set_active (id)AINSER:338 0 set_active (id)AINSER:339 0 set_active (id)AINSER:340 0 #SWICTH MIXER set_active (id)BUTTON:353 0 set_active (id)BUTTON:354 0 set_active (id)BUTTON:355 0 set_active (id)BUTTON:356 0 #POTARDS set_active (id)AINSER:365 0 set_active (id)AINSER:366 0 set_active (id)AINSER:367 0 set_active (id)AINSER:368 0 set_active (id)AINSER:369 0 set_active (id)AINSER:370 0 set_active (id)AINSER:371 0 set_active (id)AINSER:372 0 #ENC set_active (id)ENC:409 0 set_active (id)ENC:410 0 set_active (id)ENC:411 0 set_active (id)ENC:412 0 set_active (id)ENC:413 0 set_active (id)ENC:414 0 set_active (id)ENC:415 0 set_active (id)ENC:416 0 # BP ENC set_active (id)BUTTON:425 0 set_active (id)BUTTON:426 0 set_active (id)BUTTON:427 0 set_active (id)BUTTON:428 0 set_active (id)BUTTON:429 0 set_active (id)BUTTON:430 0 set_active (id)BUTTON:431 0 set_active (id)BUTTON:432 0 #FADERS set_active (id)AINSER:437 0 set_active (id)AINSER:438 0 set_active (id)AINSER:439 0 set_active (id)AINSER:440 0 #SWICTH MIXER set_active (id)BUTTON:453 0 set_active (id)BUTTON:454 0 set_active (id)BUTTON:455 0 set_active (id)BUTTON:456 0 #POTARDS set_active (id)AINSER:465 0 set_active (id)AINSER:466 0 set_active (id)AINSER:467 0 set_active (id)AINSER:468 0 set_active (id)AINSER:469 0 set_active (id)AINSER:470 0 set_active (id)AINSER:471 0 set_active (id)AINSER:472 0 exit endif if ^section == 7 log "Section is 7 " set_hsv RGBLED:269 300:100:1 set_hsv RGBLED:270 200:100:1 set_hsv RGBLED:271 100:100:10 set_hsv RGBLED:272 50:100:1 # Active # Encoders set_active (id)ENC:109 0 set_active (id)ENC:110 0 set_active (id)ENC:111 0 set_active (id)ENC:112 0 set_active (id)ENC:113 0 set_active (id)ENC:114 0 set_active (id)ENC:115 0 set_active (id)ENC:116 0 # BP ENC set_active (id)BUTTON:125 0 set_active (id)BUTTON:126 0 set_active (id)BUTTON:127 0 set_active (id)BUTTON:128 0 set_active (id)BUTTON:129 0 set_active (id)BUTTON:130 0 set_active (id)BUTTON:131 0 set_active (id)BUTTON:132 0 #FADERS set_active (id)AINSER:137 0 set_active (id)AINSER:138 0 set_active (id)AINSER:139 0 set_active (id)AINSER:140 0 #SWICTH MIXER set_active (id)BUTTON:153 0 set_active (id)BUTTON:154 0 set_active (id)BUTTON:155 0 set_active (id)BUTTON:156 0 #POTARDS set_active (id)AINSER:165 0 set_active (id)AINSER:166 0 set_active (id)AINSER:167 0 set_active (id)AINSER:168 0 set_active (id)AINSER:169 0 set_active (id)AINSER:170 0 set_active (id)AINSER:171 0 set_active (id)AINSER:172 0 # Desative #ENC set_active (id)ENC:209 0 set_active (id)ENC:210 0 set_active (id)ENC:211 0 set_active (id)ENC:212 0 set_active (id)ENC:213 0 set_active (id)ENC:214 0 set_active (id)ENC:215 0 set_active (id)ENC:216 0 # BP ENC set_active (id)BUTTON:225 0 set_active (id)BUTTON:226 0 set_active (id)BUTTON:227 0 set_active (id)BUTTON:228 0 set_active (id)BUTTON:229 0 set_active (id)BUTTON:230 0 set_active (id)BUTTON:231 0 set_active (id)BUTTON:232 0 #FADERS set_active (id)AINSER:237 0 set_active (id)AINSER:238 0 set_active (id)AINSER:239 0 set_active (id)AINSER:240 0 #SWICTH MIXER set_active (id)BUTTON:253 0 set_active (id)BUTTON:254 0 set_active (id)BUTTON:255 0 set_active (id)BUTTON:256 0 #POTARDS set_active (id)AINSER:265 0 set_active (id)AINSER:266 0 set_active (id)AINSER:267 0 set_active (id)AINSER:268 0 set_active (id)AINSER:269 0 set_active (id)AINSER:270 0 set_active (id)AINSER:271 0 set_active (id)AINSER:272 0 #ENC set_active (id)ENC:309 1 set_active (id)ENC:310 1 set_active (id)ENC:311 1 set_active (id)ENC:312 1 set_active (id)ENC:313 1 set_active (id)ENC:314 1 set_active (id)ENC:315 1 set_active (id)ENC:316 1 # BP ENC set_active (id)BUTTON:325 1 set_active (id)BUTTON:326 1 set_active (id)BUTTON:327 1 set_active (id)BUTTON:328 1 set_active (id)BUTTON:329 1 set_active (id)BUTTON:330 1 set_active (id)BUTTON:331 1 set_active (id)BUTTON:332 1 #FADERS set_active (id)AINSER:337 1 set_active (id)AINSER:338 1 set_active (id)AINSER:339 1 set_active (id)AINSER:340 1 #SWICTH MIXER set_active (id)BUTTON:353 1 set_active (id)BUTTON:354 1 set_active (id)BUTTON:355 1 set_active (id)BUTTON:356 1 #POTARDS set_active (id)AINSER:365 1 set_active (id)AINSER:366 1 set_active (id)AINSER:367 1 set_active (id)AINSER:368 1 set_active (id)AINSER:369 1 set_active (id)AINSER:370 1 set_active (id)AINSER:371 1 set_active (id)AINSER:372 1 #ENC set_active (id)ENC:409 0 set_active (id)ENC:410 0 set_active (id)ENC:411 0 set_active (id)ENC:412 0 set_active (id)ENC:413 0 set_active (id)ENC:414 0 set_active (id)ENC:415 0 set_active (id)ENC:416 0 # BP ENC set_active (id)BUTTON:425 0 set_active (id)BUTTON:426 0 set_active (id)BUTTON:427 0 set_active (id)BUTTON:428 0 set_active (id)BUTTON:429 0 set_active (id)BUTTON:430 0 set_active (id)BUTTON:431 0 set_active (id)BUTTON:432 0 #FADERS set_active (id)AINSER:437 0 set_active (id)AINSER:438 0 set_active (id)AINSER:439 0 set_active (id)AINSER:440 0 #SWICTH MIXER set_active (id)BUTTON:453 0 set_active (id)BUTTON:454 0 set_active (id)BUTTON:455 0 set_active (id)BUTTON:456 0 #POTARDS set_active (id)AINSER:465 0 set_active (id)AINSER:466 0 set_active (id)AINSER:467 0 set_active (id)AINSER:468 0 set_active (id)AINSER:469 0 set_active (id)AINSER:470 0 set_active (id)AINSER:471 0 set_active (id)AINSER:472 0 exit endif if ^section == 8 log "Section is 8 " set_hsv RGBLED:269 300:100:1 set_hsv RGBLED:270 200:100:1 set_hsv RGBLED:271 100:100:1 set_hsv RGBLED:272 50:100:10 # Active # Encoders set_active (id)ENC:109 0 set_active (id)ENC:110 0 set_active (id)ENC:111 0 set_active (id)ENC:112 0 set_active (id)ENC:113 0 set_active (id)ENC:114 0 set_active (id)ENC:115 0 set_active (id)ENC:116 0 # BP ENC set_active (id)BUTTON:125 0 set_active (id)BUTTON:126 0 set_active (id)BUTTON:127 0 set_active (id)BUTTON:128 0 set_active (id)BUTTON:129 0 set_active (id)BUTTON:130 0 set_active (id)BUTTON:131 0 set_active (id)BUTTON:132 0 #FADERS set_active (id)AINSER:137 0 set_active (id)AINSER:138 0 set_active (id)AINSER:139 0 set_active (id)AINSER:140 0 #SWICTH MIXER set_active (id)BUTTON:153 0 set_active (id)BUTTON:154 0 set_active (id)BUTTON:155 0 set_active (id)BUTTON:156 0 #POTARDS set_active (id)AINSER:165 0 set_active (id)AINSER:166 0 set_active (id)AINSER:167 0 set_active (id)AINSER:168 0 set_active (id)AINSER:169 0 set_active (id)AINSER:170 0 set_active (id)AINSER:171 0 set_active (id)AINSER:172 0 # Desative #ENC set_active (id)ENC:209 0 set_active (id)ENC:210 0 set_active (id)ENC:211 0 set_active (id)ENC:212 0 set_active (id)ENC:213 0 set_active (id)ENC:214 0 set_active (id)ENC:215 0 set_active (id)ENC:216 0 # BP ENC set_active (id)BUTTON:225 0 set_active (id)BUTTON:226 0 set_active (id)BUTTON:227 0 set_active (id)BUTTON:228 0 set_active (id)BUTTON:229 0 set_active (id)BUTTON:230 0 set_active (id)BUTTON:231 0 set_active (id)BUTTON:232 0 #FADERS set_active (id)AINSER:237 0 set_active (id)AINSER:238 0 set_active (id)AINSER:239 0 set_active (id)AINSER:240 0 #SWICTH MIXER set_active (id)BUTTON:253 0 set_active (id)BUTTON:254 0 set_active (id)BUTTON:255 0 set_active (id)BUTTON:256 0 #POTARDS set_active (id)AINSER:265 0 set_active (id)AINSER:266 0 set_active (id)AINSER:267 0 set_active (id)AINSER:268 0 set_active (id)AINSER:269 0 set_active (id)AINSER:270 0 set_active (id)AINSER:271 0 set_active (id)AINSER:272 0 #ENC set_active (id)ENC:309 0 set_active (id)ENC:310 0 set_active (id)ENC:311 0 set_active (id)ENC:312 0 set_active (id)ENC:313 0 set_active (id)ENC:314 0 set_active (id)ENC:315 0 set_active (id)ENC:316 0 # BP ENC set_active (id)BUTTON:325 0 set_active (id)BUTTON:326 0 set_active (id)BUTTON:327 0 set_active (id)BUTTON:328 0 set_active (id)BUTTON:329 0 set_active (id)BUTTON:330 0 set_active (id)BUTTON:331 0 set_active (id)BUTTON:332 0 #FADERS set_active (id)AINSER:337 0 set_active (id)AINSER:338 0 set_active (id)AINSER:339 0 set_active (id)AINSER:340 0 #SWICTH MIXER set_active (id)BUTTON:353 0 set_active (id)BUTTON:354 0 set_active (id)BUTTON:355 0 set_active (id)BUTTON:356 0 #POTARDS set_active (id)AINSER:365 0 set_active (id)AINSER:366 0 set_active (id)AINSER:367 0 set_active (id)AINSER:368 0 set_active (id)AINSER:369 0 set_active (id)AINSER:370 0 set_active (id)AINSER:371 0 set_active (id)AINSER:372 0 #ENC set_active (id)ENC:409 1 set_active (id)ENC:410 1 set_active (id)ENC:411 1 set_active (id)ENC:412 1 set_active (id)ENC:413 1 set_active (id)ENC:414 1 set_active (id)ENC:415 1 set_active (id)ENC:416 1 # BP ENC set_active (id)BUTTON:425 1 set_active (id)BUTTON:426 1 set_active (id)BUTTON:427 1 set_active (id)BUTTON:428 1 set_active (id)BUTTON:429 1 set_active (id)BUTTON:430 1 set_active (id)BUTTON:431 1 set_active (id)BUTTON:432 1 #FADERS set_active (id)AINSER:437 1 set_active (id)AINSER:438 1 set_active (id)AINSER:439 1 set_active (id)AINSER:440 1 #SWICTH MIXER set_active (id)BUTTON:453 1 set_active (id)BUTTON:454 1 set_active (id)BUTTON:455 1 set_active (id)BUTTON:456 1 #POTARDS set_active (id)AINSER:465 1 set_active (id)AINSER:466 1 set_active (id)AINSER:467 1 set_active (id)AINSER:468 1 set_active (id)AINSER:469 1 set_active (id)AINSER:470 1 set_active (id)AINSER:471 1 set_active (id)AINSER:472 1 exit endif Edited May 18, 2024 by ksir
ksir Posted May 16, 2024 Author Posted May 16, 2024 (edited) I now have to manage to turn off and on the rgbled under the switches. I succeeded with something like: Quote #NGC # LED will change brightness (v) based on value (hue statically defined) EVENT_RGBLED id= 257 dimmed=1 range= 0:10 EVENT_RGBLED id= 258 dimmed=1 range= 0:10 EVENT_RGBLED id= 259 dimmed=1 range= 0:10 EVENT_RGBLED id= 260 dimmed=1 range= 0:10 EVENT_RGBLED id= 265 dimmed=1 range= 0:10 EVENT_RGBLED id= 266 dimmed=1 range= 0:10 EVENT_RGBLED id= 267 dimmed=1 range= 0:10 EVENT_RGBLED id= 268 dimmed=1 range= 0:10 #switch #Section 1 EVENT_BUTTON id= 141 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 1 cc= 21 button_mode= Toggle hsv= 328:100:10 EVENT_BUTTON id= 142 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 1 cc= 22 button_mode= Toggle hsv= 330:100:10 EVENT_BUTTON id= 143 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 1 cc= 23 button_mode= Toggle hsv= 332:100:10 EVENT_BUTTON id= 144 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 1 cc= 24 button_mode= Toggle hsv= 334:100:10 Quote #NGR if ^section == 1 log "Section is 1" set_hsv RGBLED:261 300:100:10 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:1 set_hsv RGBLED:257 300:100:10 set_hsv RGBLED:258 300:100:10 set_hsv RGBLED:259 300:100:10 set_hsv RGBLED:260 300:100:10 if ^section == 2 log "Section is 2 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:10 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:1 set_hsv RGBLED:257 200:100:10 set_hsv RGBLED:258 200:100:10 set_hsv RGBLED:259 200:100:10 set_hsv RGBLED:260 200:100:10 Edited May 18, 2024 by ksir
