SetBankOfHwId only works on encoders?
ksir
I understood I have to use set_active .
I managed to make it work on encoder and push button
set_active (id)ENC:10 1
set_active (id)BUTTON:117 1
I didn't succeed on Ainser, I tried:
set_active (id)AINSER:133 1
#EDIT:
There were errors in my code.
It works now.
The code below works
Quote
#NGC
# EVENT	id=	0	hw_id=	0	fwd_id=LED:0	type=CC	chn=	0			cc=	0	button_mode=	Toggle	range=	0:127	fwd_to_lcd=1	rgbled_pattern=	0	hsv=	359:100:10
# Ju_Box
RESET_HW
# LCD message after load
#LCD "%C@(11:2:2)READY."
#Appel des BANKS
EVENT_BUTTON	id=	1001	hw_id=	29		type=Meta							button_mode=	OnOnly								 meta=RunSection:1
EVENT_BUTTON	id=	1002	hw_id=	30		type=Meta							button_mode=	OnOnly								 meta=RunSection:2
EVENT_BUTTON	id=	1003	hw_id=	31		type=Meta							button_mode=	OnOnly								   meta=RunSection:3
EVENT_BUTTON	id=	1004	hw_id=	32		type=Meta							button_mode=	OnOnly								meta=RunSection:4
EVENT_BUTTON	id=	1005	hw_id=	61		type=Meta							button_mode=	OnOnly								  meta=RunSection:5
EVENT_BUTTON	id=	1006	hw_id=	62		type=Meta							button_mode=	OnOnly								  meta=RunSection:6
EVENT_BUTTON	id=	1007	hw_id=	63		type=Meta							button_mode=	OnOnly								  meta=RunSection:7
EVENT_BUTTON	id=	1008	hw_id=	64		type=Meta							button_mode=	OnOnly								meta=RunSection:8
#encoder_hardware_configuration
ENC	n=	1	sr=	1	pins=1:0	type=non_detented
ENC	n=	2	sr=	1	pins=3:2	type=non_detented
ENC	n=	3	sr=	1	pins=5:4	type=non_detented
ENC	n=	4	sr=	1	pins=7:6	type=non_detented
ENC	n=	5	sr=	2	pins=1:0	type=non_detented
ENC	n=	6	sr=	2	pins=3:2	type=non_detented
ENC	n=	7	sr=	2	pins=5:4	type=non_detented
ENC	n=	8	sr=	2	pins=7:6	type=non_detented
ENC	n=	9	sr=	5	pins=1:0	type=non_detented
ENC	n=	10	sr=	5	pins=3:2	type=non_detented
ENC	n=	11	sr=	5	pins=5:4	type=non_detented
ENC	n=	12	sr=	5	pins=7:6	type=non_detented
ENC	n=	13	sr=	6	pins=1:0	type=non_detented
ENC	n=	14	sr=	6	pins=3:2	type=non_detented
ENC	n=	15	sr=	6	pins=5:4	type=non_detented
ENC	n=	16	sr=	6	pins=7:6	type=non_detented
#ainser	hardware	configuration
aINSER	n=	1	enabled=1	muxed=1	cs=0	resolution=7bit
aINSER	n=	2	enabled=0	muxed=1	cs=1	resolution=7bit
#Section 1	1
#Encoders
EVENT_ENC	id=	101	hw_id=	1	fwd_id=RGBLED:2	type=CC	chn=	1			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	328:100:10
EVENT_ENC	id=	102	hw_id=	2	fwd_id=RGBLED:18	type=CC	chn=	1			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	330:100:10
EVENT_ENC	id=	103	hw_id=	3	fwd_id=RGBLED:34	type=CC	chn=	1			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	332:100:10
EVENT_ENC	id=	104	hw_id=	4	fwd_id=RGBLED:50	type=CC	chn=	1			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	334:100:10
EVENT_ENC	id=	105	hw_id=	5	fwd_id=RGBLED:66	type=CC	chn=	1			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	336:100:10
EVENT_ENC	id=	106	hw_id=	6	fwd_id=RGBLED:82	type=CC	chn=	1			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	338:100:10
EVENT_ENC	id=	107	hw_id=	7	fwd_id=RGBLED:98	type=CC	chn=	1			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	340:100:10
EVENT_ENC	id=	108	hw_id=	8	fwd_id=RGBLED:114	type=CC	chn=	1			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	342:100:10
#Encoders	#Section5
EVENT_ENC	id=	109	hw_id=	9	fwd_id=RGBLED:130	type=CC	chn=	1			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	344:100:10
EVENT_ENC	id=	110	hw_id=	10	fwd_id=RGBLED:146	type=CC	chn=	1			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	346:100:10
EVENT_ENC	id=	111	hw_id=	11	fwd_id=RGBLED:162	type=CC	chn=	1			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	348:100:10
EVENT_ENC	id=	112	hw_id=	12	fwd_id=RGBLED:178	type=CC	chn=	1			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	350:100:10
EVENT_ENC	id=	113	hw_id=	13	fwd_id=RGBLED:194	type=CC	chn=	1			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	352:100:10
EVENT_ENC	id=	114	hw_id=	14	fwd_id=RGBLED:210	type=CC	chn=	1			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	354:100:10
EVENT_ENC	id=	115	hw_id=	15	fwd_id=RGBLED:226	type=CC	chn=	1			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	356:100:10
EVENT_ENC	id=	116	hw_id=	16	fwd_id=RGBLED:242	type=CC	chn=	1			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	358:100:10
# BP encodeurs T1	#Section 1
EVENT_BUTTON	id=	117	hw_id=	17	fwd_id=RGBLED:1	type=CC	chn=	1			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	118	hw_id=	18	fwd_id=RGBLED:17	type=CC	chn=	1			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	119	hw_id=	19	fwd_id=RGBLED:33	type=CC	chn=	1			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	120	hw_id=	20	fwd_id=RGBLED:49	type=CC	chn=	1			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	121	hw_id=	21	fwd_id=RGBLED:65	type=CC	chn=	1			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	122	hw_id=	22	fwd_id=RGBLED:81	type=CC	chn=	1			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	123	hw_id=	23	fwd_id=RGBLED:97	type=CC	chn=	1			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	124	hw_id=	24	fwd_id=RGBLED:113	type=CC	chn=	1			cc=	16	button_mode=	Toggle						hsv=	0:100:10
# BP encodeurs T2	#Section5
EVENT_BUTTON	id=	125	hw_id=	49	fwd_id=RGBLED:129	type=CC	chn=	1			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	126	hw_id=	50	fwd_id=RGBLED:145	type=CC	chn=	1			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	127	hw_id=	51	fwd_id=RGBLED:161	type=CC	chn=	1			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	128	hw_id=	52	fwd_id=RGBLED:177	type=CC	chn=	1			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	129	hw_id=	53	fwd_id=RGBLED:193	type=CC	chn=	1			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	130	hw_id=	54	fwd_id=RGBLED:209	type=CC	chn=	1			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	131	hw_id=	55	fwd_id=RGBLED:225	type=CC	chn=	1			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	132	hw_id=	56	fwd_id=RGBLED:241	type=CC	chn=	1			cc=	16	button_mode=	Toggle						hsv=	0:100:10
#---------------- 	MIXER-------------
#FADER	#Section 1
EVENT_AINSER	id=	133	hw_id=	1		type=CC	chn=	1			cc=	17			range=	0:127
EVENT_AINSER	id=	134	hw_id=	2		type=CC	chn=	1			cc=	18			range=	0:127
EVENT_AINSER	id=	135	hw_id=	3		type=CC	chn=	1			cc=	19			range=	0:127
EVENT_AINSER	id=	136	hw_id=	4		type=CC	chn=	1			cc=	20			range=	0:127
#FADER	#Section5
EVENT_AINSER	id=	137	hw_id=	5		type=CC	chn=	1			cc=	17			range=	0:127
EVENT_AINSER	id=	138	hw_id=	6		type=CC	chn=	1			cc=	18			range=	0:127
EVENT_AINSER	id=	139	hw_id=	7		type=CC	chn=	1			cc=	19			range=	0:127
EVENT_AINSER	id=	140	hw_id=	8		type=CC	chn=	1			cc=	20			range=	0:127
#switch	#Section 1
EVENT_BUTTON	id=	141	hw_id=	25	fwd_id=RGBLED:257	type=CC	chn=	1			cc=	21	button_mode=	Toggle						hsv=	328:100:10
EVENT_BUTTON	id=	142	hw_id=	26	fwd_id=RGBLED:258	type=CC	chn=	1			cc=	22	button_mode=	Toggle						hsv=	330:100:10
EVENT_BUTTON	id=	143	hw_id=	27	fwd_id=RGBLED:259	type=CC	chn=	1			cc=	23	button_mode=	Toggle						hsv=	332:100:10
EVENT_BUTTON	id=	144	hw_id=	28	fwd_id=RGBLED:260	type=CC	chn=	1			cc=	24	button_mode=	Toggle						hsv=	334:100:10
#switch	#Section5
EVENT_BUTTON	id=	153	hw_id=	57	fwd_id=RGBLED:265	type=CC	chn=	1			cc=	21	button_mode=	Toggle						hsv=	328:100:10
EVENT_BUTTON	id=	154	hw_id=	58	fwd_id=RGBLED:266	type=CC	chn=	1			cc=	22	button_mode=	Toggle						hsv=	330:100:10
EVENT_BUTTON	id=	155	hw_id=	59	fwd_id=RGBLED:267	type=CC	chn=	1			cc=	23	button_mode=	Toggle						hsv=	332:100:10
EVENT_BUTTON	id=	156	hw_id=	60	fwd_id=RGBLED:268	type=CC	chn=	1			cc=	24	button_mode=	Toggle						hsv=	334:100:10
#POTARD  T1	#Section 1
EVENT_AINSER	id=	157	hw_id=	9		type=CC	chn=	1			cc=	25			range=	0:127
EVENT_AINSER	id=	158	hw_id=	10		type=CC	chn=	1			cc=	26			range=	0:127
EVENT_AINSER	id=	159	hw_id=	11		type=CC	chn=	1			cc=	27			range=	0:127
EVENT_AINSER	id=	160	hw_id=	12		type=CC	chn=	1			cc=	28			range=	0:127
EVENT_AINSER	id=	161	hw_id=	13		type=CC	chn=	1			cc=	29			range=	0:127
EVENT_AINSER	id=	162	hw_id=	14		type=CC	chn=	1			cc=	30			range=	0:127
EVENT_AINSER	id=	163	hw_id=	15		type=CC	chn=	1			cc=	31			range=	0:127
EVENT_AINSER	id=	164	hw_id=	16		type=CC	chn=	1			cc=	32			range=	0:127
#POTARD T2	#Section5
EVENT_AINSER	id=	165	hw_id=	17		type=CC	chn=	1			cc=	25			range=	0:127
EVENT_AINSER	id=	166	hw_id=	18		type=CC	chn=	1			cc=	26			range=	0:127
EVENT_AINSER	id=	167	hw_id=	19		type=CC	chn=	1			cc=	27			range=	0:127
EVENT_AINSER	id=	168	hw_id=	20		type=CC	chn=	1			cc=	28			range=	0:127
EVENT_AINSER	id=	169	hw_id=	21		type=CC	chn=	1			cc=	29			range=	0:127
EVENT_AINSER	id=	170	hw_id=	22		type=CC	chn=	1			cc=	30			range=	0:127
EVENT_AINSER	id=	171	hw_id=	23		type=CC	chn=	1			cc=	31			range=	0:127
EVENT_AINSER	id=	172	hw_id=	24		type=CC	chn=	1			cc=	32			range=	0:127
# SECTION 2	2
#Encoders	# SECTION 2
EVENT_ENC	id=	201	hw_id=	1	fwd_id=RGBLED:2	type=CC	chn=	2			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	160:100:10
EVENT_ENC	id=	202	hw_id=	2	fwd_id=RGBLED:18	type=CC	chn=	2			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	170:100:10
EVENT_ENC	id=	203	hw_id=	3	fwd_id=RGBLED:34	type=CC	chn=	2			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	180:100:10
EVENT_ENC	id=	204	hw_id=	4	fwd_id=RGBLED:50	type=CC	chn=	2			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	190:100:10
EVENT_ENC	id=	205	hw_id=	5	fwd_id=RGBLED:66	type=CC	chn=	2			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	200:100:10
EVENT_ENC	id=	206	hw_id=	6	fwd_id=RGBLED:82	type=CC	chn=	2			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	210:100:10
EVENT_ENC	id=	207	hw_id=	7	fwd_id=RGBLED:98	type=CC	chn=	2			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	220:100:10
EVENT_ENC	id=	208	hw_id=	8	fwd_id=RGBLED:114	type=CC	chn=	2			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	230:100:10
	# SECTION 6
EVENT_ENC	id=	209	hw_id=	9	fwd_id=RGBLED:130	type=CC	chn=	2			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	160:100:10
EVENT_ENC	id=	210	hw_id=	10	fwd_id=RGBLED:146	type=CC	chn=	2			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	170:100:10
EVENT_ENC	id=	211	hw_id=	11	fwd_id=RGBLED:162	type=CC	chn=	2			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	180:100:10
EVENT_ENC	id=	212	hw_id=	12	fwd_id=RGBLED:178	type=CC	chn=	2			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	190:100:10
EVENT_ENC	id=	213	hw_id=	13	fwd_id=RGBLED:194	type=CC	chn=	2			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	200:100:10
EVENT_ENC	id=	214	hw_id=	14	fwd_id=RGBLED:210	type=CC	chn=	2			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	210:100:10
EVENT_ENC	id=	215	hw_id=	15	fwd_id=RGBLED:226	type=CC	chn=	2			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	220:100:10
EVENT_ENC	id=	216	hw_id=	16	fwd_id=RGBLED:242	type=CC	chn=	2			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	230:100:10
#bouton_poussoir_encodeurs_1	# SECTION 2
EVENT_BUTTON	id=	217	hw_id=	17	fwd_id=RGBLED:1	type=CC	chn=	2			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	218	hw_id=	18	fwd_id=RGBLED:17	type=CC	chn=	2			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	219	hw_id=	19	fwd_id=RGBLED:33	type=CC	chn=	2			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	220	hw_id=	20	fwd_id=RGBLED:49	type=CC	chn=	2			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	221	hw_id=	21	fwd_id=RGBLED:65	type=CC	chn=	2			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	222	hw_id=	22	fwd_id=RGBLED:81	type=CC	chn=	2			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	223	hw_id=	23	fwd_id=RGBLED:97	type=CC	chn=	2			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	224	hw_id=	24	fwd_id=RGBLED:113	type=CC	chn=	2			cc=	16	button_mode=	Toggle						hsv=	0:100:10
#bouton_poussoir_encodeurs_2	# SECTION 6
EVENT_BUTTON	id=	225	hw_id=	49	fwd_id=RGBLED:129	type=CC	chn=	2			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	226	hw_id=	50	fwd_id=RGBLED:145	type=CC	chn=	2			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	227	hw_id=	51	fwd_id=RGBLED:161	type=CC	chn=	2			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	228	hw_id=	52	fwd_id=RGBLED:177	type=CC	chn=	2			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	229	hw_id=	53	fwd_id=RGBLED:193	type=CC	chn=	2			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	230	hw_id=	54	fwd_id=RGBLED:209	type=CC	chn=	2			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	231	hw_id=	55	fwd_id=RGBLED:225	type=CC	chn=	2			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	232	hw_id=	56	fwd_id=RGBLED:241	type=CC	chn=	2			cc=	16	button_mode=	Toggle						hsv=	0:100:10
#FADER	# SECTION 2
EVENT_AINSER	id=	233	hw_id=	1		type=CC	chn=	2			cc=	17			range=	0:127
EVENT_AINSER	id=	234	hw_id=	2		type=CC	chn=	2			cc=	18			range=	0:127
EVENT_AINSER	id=	235	hw_id=	3		type=CC	chn=	2			cc=	19			range=	0:127
EVENT_AINSER	id=	236	hw_id=	4		type=CC	chn=	2			cc=	20			range=	0:127
	# SECTION 6
EVENT_AINSER	id=	237	hw_id=	5		type=CC	chn=	2			cc=	17			range=	0:127
EVENT_AINSER	id=	238	hw_id=	6		type=CC	chn=	2			cc=	18			range=	0:127
EVENT_AINSER	id=	239	hw_id=	7		type=CC	chn=	2			cc=	19			range=	0:127
EVENT_AINSER	id=	240	hw_id=	8		type=CC	chn=	2			cc=	20			range=	0:127
#switch	# SECTION 2
EVENT_BUTTON	id=	241	hw_id=	25	fwd_id=RGBLED:257	type=CC	chn=	2			cc=	21	button_mode=	Toggle						hsv=	220:100:10
EVENT_BUTTON	id=	242	hw_id=	26	fwd_id=RGBLED:258	type=CC	chn=	2			cc=	22	button_mode=	Toggle						hsv=	220:100:10
EVENT_BUTTON	id=	243	hw_id=	27	fwd_id=RGBLED:259	type=CC	chn=	2			cc=	23	button_mode=	Toggle						hsv=	220:100:10
EVENT_BUTTON	id=	244	hw_id=	28	fwd_id=RGBLED:260	type=CC	chn=	2			cc=	24	button_mode=	Toggle						hsv=	220:100:10
#switch	# SECTION 6
EVENT_BUTTON	id=	253	hw_id=	57	fwd_id=RGBLED:265	type=CC	chn=	2			cc=	21	button_mode=	Toggle						hsv=	220:100:10
EVENT_BUTTON	id=	254	hw_id=	58	fwd_id=RGBLED:266	type=CC	chn=	2			cc=	22	button_mode=	Toggle						hsv=	220:100:10
EVENT_BUTTON	id=	255	hw_id=	59	fwd_id=RGBLED:267	type=CC	chn=	2			cc=	23	button_mode=	Toggle						hsv=	220:100:10
EVENT_BUTTON	id=	256	hw_id=	60	fwd_id=RGBLED:268	type=CC	chn=	2			cc=	24	button_mode=	Toggle						hsv=	220:100:10
#POTARD	# SECTION 2
EVENT_AINSER	id=	257	hw_id=	9		type=CC	chn=	2			cc=	25			range=	0:127
EVENT_AINSER	id=	258	hw_id=	10		type=CC	chn=	2			cc=	26			range=	0:127
EVENT_AINSER	id=	259	hw_id=	11		type=CC	chn=	2			cc=	27			range=	0:127
EVENT_AINSER	id=	260	hw_id=	12		type=CC	chn=	2			cc=	28			range=	0:127
EVENT_AINSER	id=	261	hw_id=	13		type=CC	chn=	2			cc=	29			range=	0:127
EVENT_AINSER	id=	262	hw_id=	14		type=CC	chn=	2			cc=	30			range=	0:127
EVENT_AINSER	id=	263	hw_id=	15		type=CC	chn=	2			cc=	31			range=	0:127
EVENT_AINSER	id=	264	hw_id=	16		type=CC	chn=	2			cc=	32			range=	0:127
#POTARD	# SECTION 6
EVENT_AINSER	id=	265	hw_id=	17		type=CC	chn=	2			cc=	25			range=	0:127
EVENT_AINSER	id=	266	hw_id=	18		type=CC	chn=	2			cc=	26			range=	0:127
EVENT_AINSER	id=	267	hw_id=	19		type=CC	chn=	2			cc=	27			range=	0:127
EVENT_AINSER	id=	268	hw_id=	20		type=CC	chn=	2			cc=	28			range=	0:127
EVENT_AINSER	id=	269	hw_id=	21		type=CC	chn=	2			cc=	29			range=	0:127
EVENT_AINSER	id=	270	hw_id=	22		type=CC	chn=	2			cc=	30			range=	0:127
EVENT_AINSER	id=	271	hw_id=	23		type=CC	chn=	2			cc=	31			range=	0:127
EVENT_AINSER	id=	272	hw_id=	24		type=CC	chn=	2			cc=	32			range=	0:127
#Section  3	3
#Encoders
EVENT_ENC	id=	301	hw_id=	1	fwd_id=RGBLED:2	type=CC	chn=	3			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	302	hw_id=	2	fwd_id=RGBLED:18	type=CC	chn=	3			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	303	hw_id=	3	fwd_id=RGBLED:34	type=CC	chn=	3			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	304	hw_id=	4	fwd_id=RGBLED:50	type=CC	chn=	3			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	305	hw_id=	5	fwd_id=RGBLED:66	type=CC	chn=	3			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	306	hw_id=	6	fwd_id=RGBLED:82	type=CC	chn=	3			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	307	hw_id=	7	fwd_id=RGBLED:98	type=CC	chn=	3			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	308	hw_id=	8	fwd_id=RGBLED:114	type=CC	chn=	3			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
#Encoders	#Section   7
EVENT_ENC	id=	309	hw_id=	9	fwd_id=RGBLED:130	type=CC	chn=	3			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	310	hw_id=	10	fwd_id=RGBLED:146	type=CC	chn=	3			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	311	hw_id=	11	fwd_id=RGBLED:162	type=CC	chn=	3			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	312	hw_id=	12	fwd_id=RGBLED:178	type=CC	chn=	3			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	313	hw_id=	13	fwd_id=RGBLED:194	type=CC	chn=	3			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	314	hw_id=	14	fwd_id=RGBLED:210	type=CC	chn=	3			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	315	hw_id=	15	fwd_id=RGBLED:226	type=CC	chn=	3			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
EVENT_ENC	id=	316	hw_id=	16	fwd_id=RGBLED:242	type=CC	chn=	3			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	100:100:10
# BP encodeurs T1	#Section  3
EVENT_BUTTON	id=	317	hw_id=	17	fwd_id=RGBLED:1	type=CC	chn=	3			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	318	hw_id=	18	fwd_id=RGBLED:17	type=CC	chn=	3			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	319	hw_id=	19	fwd_id=RGBLED:33	type=CC	chn=	3			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	320	hw_id=	20	fwd_id=RGBLED:49	type=CC	chn=	3			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	321	hw_id=	21	fwd_id=RGBLED:65	type=CC	chn=	3			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	322	hw_id=	22	fwd_id=RGBLED:81	type=CC	chn=	3			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	323	hw_id=	23	fwd_id=RGBLED:97	type=CC	chn=	3			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	324	hw_id=	24	fwd_id=RGBLED:113	type=CC	chn=	3			cc=	16	button_mode=	Toggle						hsv=	0:100:10
# BP encodeurs T2	#Section   7
EVENT_BUTTON	id=	325	hw_id=	49	fwd_id=RGBLED:129	type=CC	chn=	3			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	326	hw_id=	50	fwd_id=RGBLED:145	type=CC	chn=	3			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	327	hw_id=	51	fwd_id=RGBLED:161	type=CC	chn=	3			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	328	hw_id=	52	fwd_id=RGBLED:177	type=CC	chn=	3			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	329	hw_id=	53	fwd_id=RGBLED:193	type=CC	chn=	3			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	330	hw_id=	54	fwd_id=RGBLED:209	type=CC	chn=	3			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	331	hw_id=	55	fwd_id=RGBLED:225	type=CC	chn=	3			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	332	hw_id=	56	fwd_id=RGBLED:241	type=CC	chn=	3			cc=	16	button_mode=	Toggle						hsv=	0:100:10
#FADER	#Section  3
EVENT_AINSER	id=	333	hw_id=	1		type=CC	chn=	3			cc=	17			range=	0:127
EVENT_AINSER	id=	334	hw_id=	2		type=CC	chn=	3			cc=	18			range=	0:127
EVENT_AINSER	id=	335	hw_id=	3		type=CC	chn=	3			cc=	19			range=	0:127
EVENT_AINSER	id=	336	hw_id=	4		type=CC	chn=	3			cc=	20			range=	0:127
#FADER	#Section   7
EVENT_AINSER	id=	337	hw_id=	5		type=CC	chn=	3			cc=	17			range=	0:127
EVENT_AINSER	id=	338	hw_id=	6		type=CC	chn=	3			cc=	18			range=	0:127
EVENT_AINSER	id=	339	hw_id=	7		type=CC	chn=	3			cc=	19			range=	0:127
EVENT_AINSER	id=	340	hw_id=	8		type=CC	chn=	3			cc=	20			range=	0:127
#switch	#Section  3
EVENT_BUTTON	id=	341	hw_id=	25	fwd_id=RGBLED:257	type=CC	chn=	3			cc=	21	button_mode=	Toggle						hsv=	100:100:10
EVENT_BUTTON	id=	342	hw_id=	26	fwd_id=RGBLED:258	type=CC	chn=	3			cc=	22	button_mode=	Toggle						hsv=	100:100:10
EVENT_BUTTON	id=	343	hw_id=	27	fwd_id=RGBLED:259	type=CC	chn=	3			cc=	23	button_mode=	Toggle						hsv=	100:100:10
EVENT_BUTTON	id=	344	hw_id=	28	fwd_id=RGBLED:260	type=CC	chn=	3			cc=	24	button_mode=	Toggle						hsv=	100:100:10
#switch	#Section   7
EVENT_BUTTON	id=	353	hw_id=	57	fwd_id=RGBLED:265	type=CC	chn=	3			cc=	21	button_mode=	Toggle						hsv=	100:100:10
EVENT_BUTTON	id=	354	hw_id=	58	fwd_id=RGBLED:266	type=CC	chn=	3			cc=	22	button_mode=	Toggle						hsv=	100:100:10
EVENT_BUTTON	id=	355	hw_id=	59	fwd_id=RGBLED:267	type=CC	chn=	3			cc=	23	button_mode=	Toggle						hsv=	100:100:10
EVENT_BUTTON	id=	356	hw_id=	60	fwd_id=RGBLED:268	type=CC	chn=	3			cc=	24	button_mode=	Toggle						hsv=	100:100:10
#POTARD  T1	#Section  3
EVENT_AINSER	id=	357	hw_id=	9		type=CC	chn=	3			cc=	25			range=	0:127
EVENT_AINSER	id=	358	hw_id=	10		type=CC	chn=	3			cc=	26			range=	0:127
EVENT_AINSER	id=	359	hw_id=	11		type=CC	chn=	3			cc=	27			range=	0:127
EVENT_AINSER	id=	360	hw_id=	12		type=CC	chn=	3			cc=	28			range=	0:127
EVENT_AINSER	id=	361	hw_id=	13		type=CC	chn=	3			cc=	29			range=	0:127
EVENT_AINSER	id=	362	hw_id=	14		type=CC	chn=	3			cc=	30			range=	0:127
EVENT_AINSER	id=	363	hw_id=	15		type=CC	chn=	3			cc=	31			range=	0:127
EVENT_AINSER	id=	364	hw_id=	16		type=CC	chn=	3			cc=	32			range=	0:127
#POTARD T2	#Section   7
EVENT_AINSER	id=	365	hw_id=	17		type=CC	chn=	3			cc=	25			range=	0:127
EVENT_AINSER	id=	366	hw_id=	18		type=CC	chn=	3			cc=	26			range=	0:127
EVENT_AINSER	id=	367	hw_id=	19		type=CC	chn=	3			cc=	27			range=	0:127
EVENT_AINSER	id=	368	hw_id=	20		type=CC	chn=	3			cc=	28			range=	0:127
EVENT_AINSER	id=	369	hw_id=	21		type=CC	chn=	3			cc=	29			range=	0:127
EVENT_AINSER	id=	370	hw_id=	22		type=CC	chn=	3			cc=	30			range=	0:127
EVENT_AINSER	id=	371	hw_id=	23		type=CC	chn=	3			cc=	31			range=	0:127
EVENT_AINSER	id=	372	hw_id=	24		type=CC	chn=	3			cc=	32			range=	0:127
# SECTION 4	4
#Encoders	# SECTION 4
EVENT_ENC	id=	401	hw_id=	1	fwd_id=RGBLED:2	type=CC	chn=	4			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	402	hw_id=	2	fwd_id=RGBLED:18	type=CC	chn=	4			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	403	hw_id=	3	fwd_id=RGBLED:34	type=CC	chn=	4			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	404	hw_id=	4	fwd_id=RGBLED:50	type=CC	chn=	4			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	405	hw_id=	5	fwd_id=RGBLED:66	type=CC	chn=	4			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	406	hw_id=	6	fwd_id=RGBLED:82	type=CC	chn=	4			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	407	hw_id=	7	fwd_id=RGBLED:98	type=CC	chn=	4			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	408	hw_id=	8	fwd_id=RGBLED:114	type=CC	chn=	4			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
	# SECTION 8
EVENT_ENC	id=	409	hw_id=	9	fwd_id=RGBLED:130	type=CC	chn=	4			cc=	1			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	410	hw_id=	10	fwd_id=RGBLED:146	type=CC	chn=	4			cc=	2			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	411	hw_id=	11	fwd_id=RGBLED:162	type=CC	chn=	4			cc=	3			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	412	hw_id=	12	fwd_id=RGBLED:178	type=CC	chn=	4			cc=	4			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	413	hw_id=	13	fwd_id=RGBLED:194	type=CC	chn=	4			cc=	5			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	414	hw_id=	14	fwd_id=RGBLED:210	type=CC	chn=	4			cc=	6			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	415	hw_id=	15	fwd_id=RGBLED:226	type=CC	chn=	4			cc=	7			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
EVENT_ENC	id=	416	hw_id=	16	fwd_id=RGBLED:242	type=CC	chn=	4			cc=	8			range=	0:127		rgbled_pattern=	1	hsv=	50:100:10
#bouton_poussoir_encodeurs_1	# SECTION 4
EVENT_BUTTON	id=	417	hw_id=	17	fwd_id=RGBLED:1	type=CC	chn=	4			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	418	hw_id=	18	fwd_id=RGBLED:17	type=CC	chn=	4			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	419	hw_id=	19	fwd_id=RGBLED:33	type=CC	chn=	4			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	420	hw_id=	20	fwd_id=RGBLED:49	type=CC	chn=	4			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	421	hw_id=	21	fwd_id=RGBLED:65	type=CC	chn=	4			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	422	hw_id=	22	fwd_id=RGBLED:81	type=CC	chn=	4			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	423	hw_id=	23	fwd_id=RGBLED:97	type=CC	chn=	4			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	424	hw_id=	24	fwd_id=RGBLED:113	type=CC	chn=	4			cc=	16	button_mode=	Toggle						hsv=	0:100:10
#bouton_poussoir_encodeurs_2	# SECTION 8
EVENT_BUTTON	id=	425	hw_id=	49	fwd_id=RGBLED:129	type=CC	chn=	4			cc=	9	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	426	hw_id=	50	fwd_id=RGBLED:145	type=CC	chn=	4			cc=	10	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	427	hw_id=	51	fwd_id=RGBLED:161	type=CC	chn=	4			cc=	11	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	428	hw_id=	52	fwd_id=RGBLED:177	type=CC	chn=	4			cc=	12	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	429	hw_id=	53	fwd_id=RGBLED:193	type=CC	chn=	4			cc=	13	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	430	hw_id=	54	fwd_id=RGBLED:209	type=CC	chn=	4			cc=	14	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	431	hw_id=	55	fwd_id=RGBLED:225	type=CC	chn=	4			cc=	15	button_mode=	Toggle						hsv=	0:100:10
EVENT_BUTTON	id=	432	hw_id=	56	fwd_id=RGBLED:241	type=CC	chn=	4			cc=	16	button_mode=	Toggle						hsv=	0:100:10
#FADER	# SECTION 4
EVENT_AINSER	id=	433	hw_id=	1		type=CC	chn=	4			cc=	17			range=	0:127
EVENT_AINSER	id=	434	hw_id=	2		type=CC	chn=	4			cc=	18			range=	0:127
EVENT_AINSER	id=	435	hw_id=	3		type=CC	chn=	4			cc=	19			range=	0:127
EVENT_AINSER	id=	436	hw_id=	4		type=CC	chn=	4			cc=	20			range=	0:127
	# SECTION 8
EVENT_AINSER	id=	437	hw_id=	5		type=CC	chn=	4			cc=	17			range=	0:127
EVENT_AINSER	id=	438	hw_id=	6		type=CC	chn=	4			cc=	18			range=	0:127
EVENT_AINSER	id=	439	hw_id=	7		type=CC	chn=	4			cc=	19			range=	0:127
EVENT_AINSER	id=	440	hw_id=	8		type=CC	chn=	4			cc=	20			range=	0:127
#switch	# SECTION 4
EVENT_BUTTON	id=	441	hw_id=	25	fwd_id=RGBLED:257	type=CC	chn=	4			cc=	21	button_mode=	Toggle						hsv=	50:100:10
EVENT_BUTTON	id=	442	hw_id=	26	fwd_id=RGBLED:258	type=CC	chn=	4			cc=	22	button_mode=	Toggle						hsv=	50:100:10
EVENT_BUTTON	id=	443	hw_id=	27	fwd_id=RGBLED:259	type=CC	chn=	4			cc=	23	button_mode=	Toggle						hsv=	50:100:10
EVENT_BUTTON	id=	444	hw_id=	28	fwd_id=RGBLED:260	type=CC	chn=	4			cc=	24	button_mode=	Toggle						hsv=	50:100:10
#switch	# SECTION 8
EVENT_BUTTON	id=	453	hw_id=	57	fwd_id=RGBLED:265	type=CC	chn=	4			cc=	21	button_mode=	Toggle						hsv=	50:100:10
EVENT_BUTTON	id=	454	hw_id=	58	fwd_id=RGBLED:266	type=CC	chn=	4			cc=	22	button_mode=	Toggle						hsv=	50:100:10
EVENT_BUTTON	id=	455	hw_id=	59	fwd_id=RGBLED:267	type=CC	chn=	4			cc=	23	button_mode=	Toggle						hsv=	50:100:10
EVENT_BUTTON	id=	456	hw_id=	60	fwd_id=RGBLED:268	type=CC	chn=	4			cc=	24	button_mode=	Toggle						hsv=	50:100:10
#POTARD	# SECTION 4
EVENT_AINSER	id=	457	hw_id=	9		type=CC	chn=	4			cc=	25			range=	0:127
EVENT_AINSER	id=	458	hw_id=	10		type=CC	chn=	4			cc=	26			range=	0:127
EVENT_AINSER	id=	459	hw_id=	11		type=CC	chn=	4			cc=	27			range=	0:127
EVENT_AINSER	id=	460	hw_id=	12		type=CC	chn=	4			cc=	28			range=	0:127
EVENT_AINSER	id=	461	hw_id=	13		type=CC	chn=	4			cc=	29			range=	0:127
EVENT_AINSER	id=	462	hw_id=	14		type=CC	chn=	4			cc=	30			range=	0:127
EVENT_AINSER	id=	463	hw_id=	15		type=CC	chn=	4			cc=	31			range=	0:127
EVENT_AINSER	id=	464	hw_id=	16		type=CC	chn=	4			cc=	32			range=	0:127
#POTARD	# SECTION 8
EVENT_AINSER	id=	465	hw_id=	17		type=CC	chn=	4			cc=	25			range=	0:127
EVENT_AINSER	id=	466	hw_id=	18		type=CC	chn=	4			cc=	26			range=	0:127
EVENT_AINSER	id=	467	hw_id=	19		type=CC	chn=	4			cc=	27			range=	0:127
EVENT_AINSER	id=	468	hw_id=	20		type=CC	chn=	4			cc=	28			range=	0:127
EVENT_AINSER	id=	469	hw_id=	21		type=CC	chn=	4			cc=	29			range=	0:127
EVENT_AINSER	id=	470	hw_id=	22		type=CC	chn=	4			cc=	30			range=	0:127
EVENT_AINSER	id=	471	hw_id=	23		type=CC	chn=	4			cc=	31			range=	0:127
EVENT_AINSER	id=	472	hw_id=	24		type=CC	chn=	4			cc=	32			range=	0:127
Quote
# NGR
if ^section == 0
log "Hello World!"
#	exec_meta RgbLedRainbow:5:10
delay_ms 2000
  exit
endif
if ^section == 1
  log "Section is 1"
set_hsv RGBLED:261	 300:100:10
set_hsv RGBLED:262	 200:100:1
set_hsv RGBLED:263	100:100:1
set_hsv RGBLED:264	 50:100:1
# Active
	# Encoders
	set_active 	(id)ENC:101	1
	set_active 	(id)ENC:102	1
	set_active 	(id)ENC:103	1
	set_active 	(id)ENC:104	1
	set_active 	(id)ENC:105	1
	set_active 	(id)ENC:106	1
	set_active 	(id)ENC:107	1
	set_active 	(id)ENC:108	1
	# BP ENC
	set_active 	(id)BUTTON:118	1
	set_active 	(id)BUTTON:119	1
	set_active 	(id)BUTTON:120	1
	set_active 	(id)BUTTON:121	1
	set_active 	(id)BUTTON:122	1
	set_active 	(id)BUTTON:123	1
	set_active 	(id)BUTTON:124	1
	#FADERS
	set_active 	(id)AINSER:134	1
	set_active 	(id)AINSER:135	1
	set_active 	(id)AINSER:136	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:141	1
	set_active 	(id)BUTTON:142	1
	set_active 	(id)BUTTON:143	1
	set_active 	(id)BUTTON:144	1
	#POTARDS
	set_active 	(id)AINSER:157	1
	set_active 	(id)AINSER:158	1
	set_active 	(id)AINSER:159	1
	set_active 	(id)AINSER:160	1
	set_active 	(id)AINSER:161	1
	set_active 	(id)AINSER:162	1
	set_active 	(id)AINSER:163	1
	set_active 	(id)AINSER:164	1
# Desative
	#ENC
	set_active 	(id)ENC:201	0
	set_active 	(id)ENC:202	0
	set_active 	(id)ENC:203	0
	set_active 	(id)ENC:204	0
	set_active 	(id)ENC:205	0
	set_active 	(id)ENC:206	0
	set_active 	(id)ENC:207	0
	set_active 	(id)ENC:208	0
	# BP ENC
	set_active 	(id)BUTTON:217	0
	set_active 	(id)BUTTON:218	0
	set_active 	(id)BUTTON:219	0
	set_active 	(id)BUTTON:220	0
	set_active 	(id)BUTTON:221	0
	set_active 	(id)BUTTON:222	0
	set_active 	(id)BUTTON:223	0
	set_active 	(id)BUTTON:224	0
	#FADERS
	set_active 	(id)AINSER:233	0
	set_active 	(id)AINSER:234	0
	set_active 	(id)AINSER:235	0
	set_active 	(id)AINSER:236	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:241	0
	set_active 	(id)BUTTON:242	0
	set_active 	(id)BUTTON:243	0
	set_active 	(id)BUTTON:244	0
	#POTARDS
	set_active 	(id)AINSER:257	0
	set_active 	(id)AINSER:258	0
	set_active 	(id)AINSER:259	0
	set_active 	(id)AINSER:260	0
	set_active 	(id)AINSER:261	0
	set_active 	(id)AINSER:262	0
	set_active 	(id)AINSER:263	0
	set_active 	(id)AINSER:264	0
	#ENC
	set_active 	(id)ENC:301	0
	set_active 	(id)ENC:302	0
	set_active 	(id)ENC:303	0
	set_active 	(id)ENC:304	0
	set_active 	(id)ENC:305	0
	set_active 	(id)ENC:306	0
	set_active 	(id)ENC:307	0
	set_active 	(id)ENC:308	0
	# BP ENC
	set_active 	(id)BUTTON:317	0
	set_active 	(id)BUTTON:318	0
	set_active 	(id)BUTTON:319	0
	set_active 	(id)BUTTON:320	0
	set_active 	(id)BUTTON:321	0
	set_active 	(id)BUTTON:322	0
	set_active 	(id)BUTTON:323	0
	set_active 	(id)BUTTON:324	0
	#FADERS
	set_active 	(id)AINSER:333	0
	set_active 	(id)AINSER:334	0
	set_active 	(id)AINSER:335	0
	set_active 	(id)AINSER:336	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:341	0
	set_active 	(id)BUTTON:342	0
	set_active 	(id)BUTTON:343	0
	set_active 	(id)BUTTON:344	0
	#POTARDS
	set_active 	(id)AINSER:357	0
	set_active 	(id)AINSER:358	0
	set_active 	(id)AINSER:359	0
	set_active 	(id)AINSER:360	0
	set_active 	(id)AINSER:361	0
	set_active 	(id)AINSER:362	0
	set_active 	(id)AINSER:363	0
	set_active 	(id)AINSER:364	0
	#ENC
	set_active 	(id)ENC:401	0
	set_active 	(id)ENC:402	0
	set_active 	(id)ENC:403	0
	set_active 	(id)ENC:404	0
	set_active 	(id)ENC:405	0
	set_active 	(id)ENC:406	0
	set_active 	(id)ENC:407	0
	set_active 	(id)ENC:408	0
	# BP ENC
	set_active 	(id)BUTTON:417	0
	set_active 	(id)BUTTON:418	0
	set_active 	(id)BUTTON:419	0
	set_active 	(id)BUTTON:420	0
	set_active 	(id)BUTTON:421	0
	set_active 	(id)BUTTON:422	0
	set_active 	(id)BUTTON:423	0
	set_active 	(id)BUTTON:424	0
	#FADERS
	set_active 	(id)AINSER:433	0
	set_active 	(id)AINSER:434	0
	set_active 	(id)AINSER:435	0
	set_active 	(id)AINSER:436	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:441	0
	set_active 	(id)BUTTON:442	0
	set_active 	(id)BUTTON:443	0
	set_active 	(id)BUTTON:444	0
	#POTARDS
	set_active 	(id)AINSER:457	0
	set_active 	(id)AINSER:458	0
	set_active 	(id)AINSER:459	0
	set_active 	(id)AINSER:460	0
	set_active 	(id)AINSER:461	0
	set_active 	(id)AINSER:462	0
	set_active 	(id)AINSER:463	0
	set_active 	(id)AINSER:464	0
  exit
  endif
if ^section == 	2
  log "Section is 	2	"
set_hsv RGBLED:262	 200:100:10
# Active
	# Encoders
	set_active 	(id)ENC:101	0
	set_active 	(id)ENC:102	0
	set_active 	(id)ENC:103	0
	set_active 	(id)ENC:104	0
	set_active 	(id)ENC:105	0
	set_active 	(id)ENC:106	0
	set_active 	(id)ENC:107	0
	set_active 	(id)ENC:108	0
	# BP ENC
	set_active 	(id)BUTTON:117	0
	set_active 	(id)BUTTON:118	0
	set_active 	(id)BUTTON:119	0
	set_active 	(id)BUTTON:120	0
	set_active 	(id)BUTTON:121	0
	set_active 	(id)BUTTON:122	0
	set_active 	(id)BUTTON:123	0
	set_active 	(id)BUTTON:124	0
	#FADERS
	set_active 	(id)AINSER:133 	0
	set_active 	(id)AINSER:134	0
	set_active 	(id)AINSER:135	0
	set_active 	(id)AINSER:136	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:141	0
	set_active 	(id)BUTTON:142	0
	set_active 	(id)BUTTON:143	0
	set_active 	(id)BUTTON:144	0
	#POTARDS		0
	set_active 	(id)AINSER:157	0
	set_active 	(id)AINSER:158	0
	set_active 	(id)AINSER:159	0
	set_active 	(id)AINSER:160	0
	set_active 	(id)AINSER:161	0
	set_active 	(id)AINSER:162	0
	set_active 	(id)AINSER:163	0
	set_active 	(id)AINSER:164	0
# Desative
	#ENC
	set_active 	(id)ENC:201	1
	set_active 	(id)ENC:202	1
	set_active 	(id)ENC:203	1
	set_active 	(id)ENC:204	1
	set_active 	(id)ENC:205	1
	set_active 	(id)ENC:206	1
	set_active 	(id)ENC:207	1
	set_active 	(id)ENC:208	1
	# BP ENC
	set_active 	(id)BUTTON:217	1
	set_active 	(id)BUTTON:218	1
	set_active 	(id)BUTTON:219	1
	set_active 	(id)BUTTON:220	1
	set_active 	(id)BUTTON:221	1
	set_active 	(id)BUTTON:222	1
	set_active 	(id)BUTTON:223	1
	set_active 	(id)BUTTON:224	1
	#FADERS
	set_active 	(id)AINSER:233	1
	set_active 	(id)AINSER:234	1
	set_active 	(id)AINSER:235	1
	set_active 	(id)AINSER:236	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:241	1
	set_active 	(id)BUTTON:242	1
	set_active 	(id)BUTTON:243	1
	set_active 	(id)BUTTON:244	1
	#POTARDS
	set_active 	(id)AINSER:257	1
	set_active 	(id)AINSER:258	1
	set_active 	(id)AINSER:259	1
	set_active 	(id)AINSER:260	1
	set_active 	(id)AINSER:261	1
	set_active 	(id)AINSER:262	1
	set_active 	(id)AINSER:263	1
	set_active 	(id)AINSER:264	1
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
  exit
  endif
if ^section == 	3
  log "Section is 	3	"
set_hsv RGBLED:263	100:100:10
# Active
	# Encoders
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
# Desative
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	set_active 	(id)ENC:301	1
	set_active 	(id)ENC:302	1
	set_active 	(id)ENC:303	1
	set_active 	(id)ENC:304	1
	set_active 	(id)ENC:305	1
	set_active 	(id)ENC:306	1
	set_active 	(id)ENC:307	1
	set_active 	(id)ENC:308	1
	# BP ENC
	set_active 	(id)BUTTON:317	1
	set_active 	(id)BUTTON:318	1
	set_active 	(id)BUTTON:319	1
	set_active 	(id)BUTTON:320	1
	set_active 	(id)BUTTON:321	1
	set_active 	(id)BUTTON:322	1
	set_active 	(id)BUTTON:323	1
	set_active 	(id)BUTTON:324	1
	#FADERS
	set_active 	(id)AINSER:333	1
	set_active 	(id)AINSER:334	1
	set_active 	(id)AINSER:335	1
	set_active 	(id)AINSER:336	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:341	1
	set_active 	(id)BUTTON:342	1
	set_active 	(id)BUTTON:343	1
	set_active 	(id)BUTTON:344	1
	#POTARDS
	set_active 	(id)AINSER:357	1
	set_active 	(id)AINSER:358	1
	set_active 	(id)AINSER:359	1
	set_active 	(id)AINSER:360	1
	set_active 	(id)AINSER:361	1
	set_active 	(id)AINSER:362	1
	set_active 	(id)AINSER:363	1
	set_active 	(id)AINSER:364	1
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
  exit
  endif
if ^section == 	4
  log "Section is 	4	"
set_hsv RGBLED:264	 50:100:10
# Active
	# Encoders
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS		0
# Desative
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	set_active 	(id)ENC:401	1
	set_active 	(id)ENC:402	1
	set_active 	(id)ENC:403	1
	set_active 	(id)ENC:404	1
	set_active 	(id)ENC:405	1
	set_active 	(id)ENC:406	1
	set_active 	(id)ENC:407	1
	set_active 	(id)ENC:408	1
	# BP ENC
	set_active 	(id)BUTTON:417	1
	set_active 	(id)BUTTON:418	1
	set_active 	(id)BUTTON:419	1
	set_active 	(id)BUTTON:420	1
	set_active 	(id)BUTTON:421	1
	set_active 	(id)BUTTON:422	1
	set_active 	(id)BUTTON:423	1
	set_active 	(id)BUTTON:424	1
	#FADERS
	set_active 	(id)AINSER:433	1
	set_active 	(id)AINSER:434	1
	set_active 	(id)AINSER:435	1
	set_active 	(id)AINSER:436	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:441	1
	set_active 	(id)BUTTON:442	1
	set_active 	(id)BUTTON:443	1
	set_active 	(id)BUTTON:444	1
	#POTARDS
	set_active 	(id)AINSER:457	1
	set_active 	(id)AINSER:458	1
	set_active 	(id)AINSER:459	1
	set_active 	(id)AINSER:460	1
	set_active 	(id)AINSER:461	1
	set_active 	(id)AINSER:462	1
	set_active 	(id)AINSER:463	1
	set_active 	(id)AINSER:464	1
  exit
  endif
if ^section == 	5
  log "Section is 	5	"
set_hsv RGBLED:269	 300:100:10
set_hsv RGBLED:270	 200:100:1
set_hsv RGBLED:271	100:100:1
set_hsv RGBLED:272	 50:100:1
# Active
	# Encoders
	set_active 	(id)ENC:109	1
	set_active 	(id)ENC:110	1
	set_active 	(id)ENC:111	1
	set_active 	(id)ENC:112	1
	set_active 	(id)ENC:113	1
	set_active 	(id)ENC:114	1
	set_active 	(id)ENC:115	1
	set_active 	(id)ENC:116	1
	# BP ENC
	set_active 	(id)BUTTON:125	1
	set_active 	(id)BUTTON:126	1
	set_active 	(id)BUTTON:127	1
	set_active 	(id)BUTTON:128	1
	set_active 	(id)BUTTON:129	1
	set_active 	(id)BUTTON:130	1
	set_active 	(id)BUTTON:131	1
	set_active 	(id)BUTTON:132	1
	#FADERS
	set_active 	(id)AINSER:137	1
	set_active 	(id)AINSER:138	1
	set_active 	(id)AINSER:139	1
	set_active 	(id)AINSER:140	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:153	1
	set_active 	(id)BUTTON:154	1
	set_active 	(id)BUTTON:155	1
	set_active 	(id)BUTTON:156	1
	#POTARDS
	set_active 	(id)AINSER:165	1
	set_active 	(id)AINSER:166	1
	set_active 	(id)AINSER:167	1
	set_active 	(id)AINSER:168	1
	set_active 	(id)AINSER:169	1
	set_active 	(id)AINSER:170	1
	set_active 	(id)AINSER:171	1
	set_active 	(id)AINSER:172	1
# Desative
	#ENC
	set_active 	(id)ENC:209	0
	set_active 	(id)ENC:210	0
	set_active 	(id)ENC:211	0
	set_active 	(id)ENC:212	0
	set_active 	(id)ENC:213	0
	set_active 	(id)ENC:214	0
	set_active 	(id)ENC:215	0
	set_active 	(id)ENC:216	0
	# BP ENC
	set_active 	(id)BUTTON:225	0
	set_active 	(id)BUTTON:226	0
	set_active 	(id)BUTTON:227	0
	set_active 	(id)BUTTON:228	0
	set_active 	(id)BUTTON:229	0
	set_active 	(id)BUTTON:230	0
	set_active 	(id)BUTTON:231	0
	set_active 	(id)BUTTON:232	0
	#FADERS
	set_active 	(id)AINSER:237	0
	set_active 	(id)AINSER:238	0
	set_active 	(id)AINSER:239	0
	set_active 	(id)AINSER:240	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:253	0
	set_active 	(id)BUTTON:254	0
	set_active 	(id)BUTTON:255	0
	set_active 	(id)BUTTON:256	0
	#POTARDS
	set_active 	(id)AINSER:265	0
	set_active 	(id)AINSER:266	0
	set_active 	(id)AINSER:267	0
	set_active 	(id)AINSER:268	0
	set_active 	(id)AINSER:269	0
	set_active 	(id)AINSER:270	0
	set_active 	(id)AINSER:271	0
	set_active 	(id)AINSER:272	0
	#ENC
	set_active 	(id)ENC:309	0
	set_active 	(id)ENC:310	0
	set_active 	(id)ENC:311	0
	set_active 	(id)ENC:312	0
	set_active 	(id)ENC:313	0
	set_active 	(id)ENC:314	0
	set_active 	(id)ENC:315	0
	set_active 	(id)ENC:316	0
	# BP ENC
	set_active 	(id)BUTTON:325	0
	set_active 	(id)BUTTON:326	0
	set_active 	(id)BUTTON:327	0
	set_active 	(id)BUTTON:328	0
	set_active 	(id)BUTTON:329	0
	set_active 	(id)BUTTON:330	0
	set_active 	(id)BUTTON:331	0
	set_active 	(id)BUTTON:332	0
	#FADERS
	set_active 	(id)AINSER:337	0
	set_active 	(id)AINSER:338	0
	set_active 	(id)AINSER:339	0
	set_active 	(id)AINSER:340	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:353	0
	set_active 	(id)BUTTON:354	0
	set_active 	(id)BUTTON:355	0
	set_active 	(id)BUTTON:356	0
	#POTARDS
	set_active 	(id)AINSER:365	0
	set_active 	(id)AINSER:366	0
	set_active 	(id)AINSER:367	0
	set_active 	(id)AINSER:368	0
	set_active 	(id)AINSER:369	0
	set_active 	(id)AINSER:370	0
	set_active 	(id)AINSER:371	0
	set_active 	(id)AINSER:372	0
	#ENC
	set_active 	(id)ENC:409	0
	set_active 	(id)ENC:410	0
	set_active 	(id)ENC:411	0
	set_active 	(id)ENC:412	0
	set_active 	(id)ENC:413	0
	set_active 	(id)ENC:414	0
	set_active 	(id)ENC:415	0
	set_active 	(id)ENC:416	0
	# BP ENC
	set_active 	(id)BUTTON:425	0
	set_active 	(id)BUTTON:426	0
	set_active 	(id)BUTTON:427	0
	set_active 	(id)BUTTON:428	0
	set_active 	(id)BUTTON:429	0
	set_active 	(id)BUTTON:430	0
	set_active 	(id)BUTTON:431	0
	set_active 	(id)BUTTON:432	0
	#FADERS
	set_active 	(id)AINSER:437	0
	set_active 	(id)AINSER:438	0
	set_active 	(id)AINSER:439	0
	set_active 	(id)AINSER:440	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:453	0
	set_active 	(id)BUTTON:454	0
	set_active 	(id)BUTTON:455	0
	set_active 	(id)BUTTON:456	0
	#POTARDS
	set_active 	(id)AINSER:465	0
	set_active 	(id)AINSER:466	0
	set_active 	(id)AINSER:467	0
	set_active 	(id)AINSER:468	0
	set_active 	(id)AINSER:469	0
	set_active 	(id)AINSER:470	0
	set_active 	(id)AINSER:471	0
	set_active 	(id)AINSER:472	0
  exit
  endif
if ^section == 	6
  log "Section is 	6	"
set_hsv RGBLED:270	 200:100:10
# Active
	# Encoders
	set_active 	(id)ENC:109	0
	set_active 	(id)ENC:110	0
	set_active 	(id)ENC:111	0
	set_active 	(id)ENC:112	0
	set_active 	(id)ENC:113	0
	set_active 	(id)ENC:114	0
	set_active 	(id)ENC:115	0
	set_active 	(id)ENC:116	0
	# BP ENC
	set_active 	(id)BUTTON:125	0
	set_active 	(id)BUTTON:126	0
	set_active 	(id)BUTTON:127	0
	set_active 	(id)BUTTON:128	0
	set_active 	(id)BUTTON:129	0
	set_active 	(id)BUTTON:130	0
	set_active 	(id)BUTTON:131	0
	set_active 	(id)BUTTON:132	0
	#FADERS
	set_active 	(id)AINSER:137	0
	set_active 	(id)AINSER:138	0
	set_active 	(id)AINSER:139	0
	set_active 	(id)AINSER:140	0
	#SWICTH MIXER
	set_active 	(id)BUTTON:153	0
	set_active 	(id)BUTTON:154	0
	set_active 	(id)BUTTON:155	0
	set_active 	(id)BUTTON:156	0
	#POTARDS
	set_active 	(id)AINSER:165	0
	set_active 	(id)AINSER:166	0
	set_active 	(id)AINSER:167	0
	set_active 	(id)AINSER:168	0
	set_active 	(id)AINSER:169	0
	set_active 	(id)AINSER:170	0
	set_active 	(id)AINSER:171	0
	set_active 	(id)AINSER:172	0
# Desative
	#ENC
	set_active 	(id)ENC:209	1
	set_active 	(id)ENC:210	1
	set_active 	(id)ENC:211	1
	set_active 	(id)ENC:212	1
	set_active 	(id)ENC:213	1
	set_active 	(id)ENC:214	1
	set_active 	(id)ENC:215	1
	set_active 	(id)ENC:216	1
	# BP ENC
	set_active 	(id)BUTTON:225	1
	set_active 	(id)BUTTON:226	1
	set_active 	(id)BUTTON:227	1
	set_active 	(id)BUTTON:228	1
	set_active 	(id)BUTTON:229	1
	set_active 	(id)BUTTON:230	1
	set_active 	(id)BUTTON:231	1
	set_active 	(id)BUTTON:232	1
	#FADERS
	set_active 	(id)AINSER:237	1
	set_active 	(id)AINSER:238	1
	set_active 	(id)AINSER:239	1
	set_active 	(id)AINSER:240	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:253	1
	set_active 	(id)BUTTON:254	1
	set_active 	(id)BUTTON:255	1
	set_active 	(id)BUTTON:256	1
	#POTARDS
	set_active 	(id)AINSER:265	1
	set_active 	(id)AINSER:266	1
	set_active 	(id)AINSER:267	1
	set_active 	(id)AINSER:268	1
	set_active 	(id)AINSER:269	1
	set_active 	(id)AINSER:270	1
	set_active 	(id)AINSER:271	1
	set_active 	(id)AINSER:272	1
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
  exit
  endif
if ^section == 	7
  log "Section is 	7	"
set_hsv RGBLED:271	100:100:10
# Active
	# Encoders
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
# Desative
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	set_active 	(id)ENC:309	1
	set_active 	(id)ENC:310	1
	set_active 	(id)ENC:311	1
	set_active 	(id)ENC:312	1
	set_active 	(id)ENC:313	1
	set_active 	(id)ENC:314	1
	set_active 	(id)ENC:315	1
	set_active 	(id)ENC:316	1
	# BP ENC
	set_active 	(id)BUTTON:325	1
	set_active 	(id)BUTTON:326	1
	set_active 	(id)BUTTON:327	1
	set_active 	(id)BUTTON:328	1
	set_active 	(id)BUTTON:329	1
	set_active 	(id)BUTTON:330	1
	set_active 	(id)BUTTON:331	1
	set_active 	(id)BUTTON:332	1
	#FADERS
	set_active 	(id)AINSER:337	1
	set_active 	(id)AINSER:338	1
	set_active 	(id)AINSER:339	1
	set_active 	(id)AINSER:340	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:353	1
	set_active 	(id)BUTTON:354	1
	set_active 	(id)BUTTON:355	1
	set_active 	(id)BUTTON:356	1
	#POTARDS
	set_active 	(id)AINSER:365	1
	set_active 	(id)AINSER:366	1
	set_active 	(id)AINSER:367	1
	set_active 	(id)AINSER:368	1
	set_active 	(id)AINSER:369	1
	set_active 	(id)AINSER:370	1
	set_active 	(id)AINSER:371	1
	set_active 	(id)AINSER:372	1
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
  exit
  endif
if ^section == 	8
  log "Section is 	8	"
set_hsv RGBLED:272	 50:100:10
# Active
	# Encoders
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
# Desative
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	# BP ENC
	#FADERS
	#SWICTH MIXER
	#POTARDS
	#ENC
	set_active 	(id)ENC:409	1
	set_active 	(id)ENC:410	1
	set_active 	(id)ENC:411	1
	set_active 	(id)ENC:412	1
	set_active 	(id)ENC:413	1
	set_active 	(id)ENC:414	1
	set_active 	(id)ENC:415	1
	set_active 	(id)ENC:416	1
	# BP ENC
	set_active 	(id)BUTTON:425	1
	set_active 	(id)BUTTON:426	1
	set_active 	(id)BUTTON:427	1
	set_active 	(id)BUTTON:428	1
	set_active 	(id)BUTTON:429	1
	set_active 	(id)BUTTON:430	1
	set_active 	(id)BUTTON:431	1
	set_active 	(id)BUTTON:432	1
	#FADERS
	set_active 	(id)AINSER:437	1
	set_active 	(id)AINSER:438	1
	set_active 	(id)AINSER:439	1
	set_active 	(id)AINSER:440	1
	#SWICTH MIXER
	set_active 	(id)BUTTON:453	1
	set_active 	(id)BUTTON:454	1
	set_active 	(id)BUTTON:455	1
	set_active 	(id)BUTTON:456	1
	#POTARDS
	set_active 	(id)AINSER:465	1
	set_active 	(id)AINSER:466	1
	set_active 	(id)AINSER:467	1
	set_active 	(id)AINSER:468	1
	set_active 	(id)AINSER:469	1
	set_active 	(id)AINSER:470	1
	set_active 	(id)AINSER:471	1
	set_active 	(id)AINSER:472	1
  exit
  endif
Edited by ksir
I now have to manage to turn off and on the rgbled under the switches.
I succeeded with something like:
Quote
#NGC
# LED will change brightness (v) based on value (hue statically defined)
EVENT_RGBLED	id=	257			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	258			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	259			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	260			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	265			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	266			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	267			dimmed=1 										 range=	0:10
EVENT_RGBLED	id=	268			dimmed=1 										 range=	0:10
#switch	#Section 1
Quote
#NGR
if ^section == 1
  log "Section is 1"
set_hsv RGBLED:257	 300:100:10
set_hsv RGBLED:258	 300:100:10
set_hsv RGBLED:259	 300:100:10
set_hsv RGBLED:260	 300:100:10
if ^section == 	2
  log "Section is 	2	"
set_hsv RGBLED:257	 200:100:10
set_hsv RGBLED:258	 200:100:10
set_hsv RGBLED:259	 200:100:10
set_hsv RGBLED:260	 200:100:10
Edited by ksir
