anonyme-x22 Posted March 31, 2025 Posted March 31, 2025 (edited) Hello, I try to remove the view step of the step button. I suppose replacing: this: static s32 SEQ_UI_Button_StepView(s32 depressed) { // static seq_ui_page_t prev_page = SEQ_UI_PAGE_NONE; // also used by seq_ui_stepsel static seq_ui_sel_view_t prev_sel_view = SEQ_UI_SEL_VIEW_NONE; if( !depressed ) { prev_sel_view = seq_ui_sel_view; seq_ui_sel_view = SEQ_UI_SEL_VIEW_STEPS; seq_ui_button_state.TAKE_OVER_SEL_VIEW = 1; if( ui_page == SEQ_UI_PAGE_MUTE || SEQ_UI_PAGE_PATTERN || ui_page == SEQ_UI_PAGE_SONG ) SEQ_UI_PageSet(SEQ_UI_PAGE_EDIT); // this selection only makes sense in EDIT page } else { if( !seq_ui_button_state.TAKE_OVER_SEL_VIEW ) seq_ui_sel_view = prev_sel_view; } if( seq_hwcfg_button_beh.step_view ) { if( depressed ) return -1; // ignore when button depressed if( !seq_ui_button_state.STEP_VIEW ) // due to page change: button going to be set, clear other toggle buttons seq_ui_button_state.PAGE_CHANGE_BUTTON_FLAGS = 0; seq_ui_button_state.STEP_VIEW ^= 1; // toggle STEP_VIEW pressed (will also be released once GP button has been pressed) } else { // set mode seq_ui_button_state.STEP_VIEW = depressed ? 0 : 1; } if( seq_ui_button_state.STEP_VIEW ) { ui_stepview_prev_page = ui_page; SEQ_UI_PageSet(SEQ_UI_PAGE_STEPSEL); } else { if( ui_page == SEQ_UI_PAGE_STEPSEL ) SEQ_UI_PageSet(ui_stepview_prev_page); } return 0; // no error } by this: static s32 SEQ_UI_Button_StepView(s32 depressed) { // static seq_ui_page_t prev_page = SEQ_UI_PAGE_NONE; // also used by seq_ui_stepsel static seq_ui_sel_view_t prev_sel_view = SEQ_UI_SEL_VIEW_NONE; SEQ_UI_PageSet(SEQ_UI_PAGE_STEPSEL); return 0; // no error } Also i suppose i have to replace this: SEQ_LED_PinSet(seq_hwcfg_led.step_view, ui_page == SEQ_UI_PAGE_STEPSEL || (selbuttons_available && seq_ui_sel_view == SEQ_UI_SEL_VIEW_STEPS)); by this: SEQ_LED_PinSet(seq_hwcfg_led.step_view, ui_page == SEQ_UI_PAGE_STEPSEL )); Als is there a way i can test the code without uploading it into the seq? Thanks in advance, Edited March 31, 2025 by anonyme-x22
