Rowan Posted November 21, 2004 Report Posted November 21, 2004 Hi,I'm going to go buy some LED's this week for my MBLC this week. I've used 3mm 15mcd LED's in it so far, but they aren't bright enough so i'm going to replace them with new ones.The buttons I'm using have an LED socket built in, you pop the frosted cover off and put the LED behind the button cap.I want some LED's that make the buttons glow nice and bright. I can also put littel lables behind the caps.How many mcd do you guys suggest 500mcd? Â 2000mcd?I don't knowRegardsRowan ??? ???
Duggle Posted November 21, 2004 Report Posted November 21, 2004 500mcd would be >30 times brighter than what youve tried. The really intense ones tend to have a narrow projection angle which might not be so good if these are for a backlight. I reckon 100 to 150mcd with 60degree view angle ( or similar) might be worth a try.
Rowan Posted November 21, 2004 Author Report Posted November 21, 2004 Thanks duggle,I'll give it a try tommrow.Good point about the viewing angle, hadn't thought 'bout that.RegardsRowan
Rowan Posted November 28, 2004 Author Report Posted November 28, 2004 Got 500mcd 30 degree viwing angle LED's in the end, they work a treatRegardsRowan
