banneduser Posted November 15, 2004 Posted November 15, 2004 Hi thereI'm builing a box with 14 buttons using only the the Core and DIN modules. Whenever I load any syx file it looks to load ok using MIDI-OX or the sysebox but the only data i'm recieving from the box is a sys ex message of:F0 00 00 7E 40 12 01 F7This repeats every 2 secondsAny help would be greatly appreciatedRohan
Tanstaafl Posted November 15, 2004 Posted November 15, 2004 Looks like you only have mios burned on the pic.have you downloaded (via midi connection) your application to the pic?
banneduser Posted November 16, 2004 Author Posted November 16, 2004 I loaded midibox 64 v2.3 via midi which did stop the sys ex data but the buttons were not producing any data and when I powered down and back up again the original data repeats every 2 seconds
goyousalukis Posted November 16, 2004 Posted November 16, 2004 No - the 2 second message means you don't have mios loaded yet. You only have the bootstrap loader.You need to send the mios_v1_7.syx file from the MIOS download first - then send the main.syx from the MidiBox64. Remember you need to ground A0-A7 of J5 on the core if you aren't using any Pots. (or you can change the number of connected pots to 0 in the main.asm and re-assemble it.)Justinp.s. This really isn't a MIOS Programming question - it should be posted under Testing/Troubleshooting.
