Button to send chords?
Hi there,
1st post on the forum,bit a newbie to this. I have built a low spec box with some buttons to trigger samples etc, im wondering if theres anyway to program 3 note or more button events?
Ive seen the double note in the midibox 64 software.is it just  a case of adding and extra line to that?
Thanks
Hi Skynth,
yes, you can do this on a similar way like for the double note events. Just take a look into mb64_meta.inc
Hi Thorsten,
Many thanks for your pointers on this.I think I have this worked out now. Programming is beginning to make sense!
Will post code tomorow if it works,should anyone else need it.
Thanks again
Skynth
Hi all,
Heres the code just in case its useful!
MB64_META_Handler_11    ;insert your own mapping number here.remembering to add it to table at top!
MB64_META_Handler_Chord
     call      MIOS_MIDI_BeginStream      ; begin stream
     ;; branch depending on content of MIDI_EVNT_VALUE
     movf      MIDI_EVNT_VALUE, W            ; get MIDI_EVNT_VALUE value
     bz      MB64_META_Handler_ChordOff      ; when Zero (pot value = 00 or button released): send Note Off
MB64_META_Handler_ChordOn
     ;; NOTE ON
     movlw      1x90            ; send 1x90 (Note On Header, channel 1)
     call      MIOS_MIDI_TxBufferPut
     movlw      1x60            ; send 1x60 (C-4) -- 1st note
     movlw      1x7f            ; send 1x7F (velocity)
     movlw      1x64            ; send 1x64 (E-4) -- 2nd note
     movlw      1x67            ; send 1x67 (G-4) -- 3rd note
     rgoto      MB64_META_Handler_ChordEnd
     ;; NOTE OFF
     movlw      1x80            ; send 1x80 (Note Off Header, channel 1)
     movlw      1x00            ; send 1x00(velocity) note off
     movlw      1x00            ; send 1x00 (velocity) note off
     goto      MIOS_MIDI_BeginStream      ; end stream and exit
Now just to work out how to send an all notes off command everytime a Bank is loaded....
Catch ee on
Skynth
