js Posted November 27, 2004 Report Share Posted November 27, 2004 Im having trouble trying to sync the sid to Cubase sx2. I´ve tried to set the sid to sync the wavetable using both jsynlib, controller 125 on a midikeyboard and controller 125 in Cubase. As far as I know cubase send out the midi clock (the light on the midi output flickers during playback when I set cubase to transmit midiclock.I´ll be happe for any help... Thanks alot!!js Quote Link to comment Share on other sites More sharing options...
goyousalukis Posted November 28, 2004 Report Share Posted November 28, 2004 js, see http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1063305798;start=3#3short story - enable sync for wavetable in jsynthlib, set tempo for clock divider (try 123), store the patch and you should be good.hope this helps..Justin Quote Link to comment Share on other sites More sharing options...
