MrJingle Posted December 4, 2004 Posted December 4, 2004 Hi!I'm building a MIDI filter using this design:http://www.ucapps.de/midifilter.htmlI want the unit to be self-powered via MIDI like the Midisolutions' products:http://www.midisolutions.com/products.htmThey mention in the FAQ that the optoisolator is removed in the MIDI input of circuit to be able to power the device.http://www.midisolutions.com/faqs.htm (Q: Will inserting MIDI Solutions products in my setup cause ground loops?)I want to remove the optoisolator in the Filter design but I do not know what remaining parts are needed for the circuit to function properly.Could some electronically skilled person help me with a proper solution?Regards, MrJingle
TK. Posted December 4, 2004 Posted December 4, 2004 Hi,also the MIDIbox project has a FAQ:http://www.avishowtech.com/midibox/wiki/index.php/Question%20and%20Answers#QA37(there is no proper solution)Best Regards, Thorsten.
MrJingle Posted December 4, 2004 Author Posted December 4, 2004 Thanks a lot for your quick reply!I'm definately NOT an experienced electronic expert, but my approach is "learning by doing" so I'll give the hinted solution in the FAQ a shot.I suppose that the reason the Midisolutions' stuff works is that they don't use PIC's for their units, right?Regards, MrJingle
