banneduser Posted December 20, 2004 Posted December 20, 2004 hey guysi've been thinking of this little hardware addon. must be easy to buildthe thing is, in place of a pot on an analog input, u connect another circuit.the circuit consists of a bandpass filter, and another gain stage.first, u input a line level audio, with the bandpass filter u only get the frequency range u want.the gain stage is just for normalizing the level to be +5v max peak.also i assume you would need somekind of a rectifier, to get DC kind of signal out of the AC music signal. this could be easily achieved with a diode (of course, compensating the forward voltage drop of .7v (.3 on a germanium))with the proper setup u can have a *sidechain* kind of input to "compress" some signal on the presence of another.or you can simply use it to modulate some controller by another signal..oh well u get the idea :)thats bout itany suggestions are welcomecheers
pay_c Posted December 20, 2004 Posted December 20, 2004 Yepp, in modular synthesizers your idea is called a "EIEF", meaning: External Input Envelope FollowerThere are kinda many schematics out there doing that (the most ones without bandpassing!).Anyhow: The schematic is NOT that easy! The bandpass filtering, the input / output stage, the envelope filtering and so on should fill up at least 1/2 of a 160x100mm PCB in best case I think.
banneduser Posted December 20, 2004 Author Posted December 20, 2004 but yet.. its doable :)it can be an external addon box aswellbut its interestingi'll try implement it some of these days
AndrewMartens Posted December 20, 2004 Posted December 20, 2004 It might be possible to achieve in less space:- input buffer, single opamp- bandpass stage, OTA, possibly another opamp- you might be able to find an IC that measures AC RMS and outputs a DC voltage and use thatBut yeah, essentially what you're looking for is an envelope follower schematic. Tacking a bandpass filter on in front of it just allows you to isolate a certain set of frequencies (which could be handy in some circumstances)...
