jon Posted December 27, 2004 Posted December 27, 2004 Is it possible to leave the select buttons and just use the menu button? Its a bit slower, but is it possible? Instead of push the selekt button for edit mode, just turn the data wheel and press the menu.../Jon
jdutcher Posted December 27, 2004 Posted December 27, 2004 from what i understand, you want only ONE encoder and ONE button? Â if that is what you want, it won't work. Â you'd need at least one select button also. Â the menu button ONLY serves to go to the previous (higher) tier of the menu.EDIT: on second thought, you might be able to get your setup working if you altered the code a bit, adding an "exit" item to each level of the menu. however, if this is beyond your capabilities, you're gonna need more than one button.
jon Posted December 28, 2004 Author Posted December 28, 2004 Yeah ok.I thought the exit thing sould do the thing. Im trying to understand all the code now to do my own setup. But the one button thing I leave behind for a while. Thanx.
TK. Posted January 2, 2005 Posted January 2, 2005 Hi Jon,it's impossible to edit the patch name with only one menu button. Who knows which other features will be added in future which rely on the select buttons --- therefore I cannot suggest this design changeBest Regards, Thorsten.
