I read it's possible to disable the menu buttons and make them programmable.  If this is indeed possible, I do not know how to do it.
My menu buttons do not generate any midi traffic (i want them to), and i can only assume that they are either not working, or changing menus on the lcd, which I do not have (im using this for an alternate application)
I looked through the options on the windows midibox64 but could not find about making the menu buttons programmable.  I have successfully programmed my other buttons as controllers.
I figure i can put together another din for the extra buttons that are currently not working  (i need all 32 to work), but i thought id check into this first.
Thanks,
Bret
Hi Bret,
to disable the menu buttons you have to edit the main.asm file:
  #define DEFAULT_DIN_MENU_EXEC         0xff ; disabled
  #define DEFAULT_DIN_MENU_RIGHT        0xff       ; disabled
  #define DEFAULT_DIN_MENU_LEFT         0xff       ; disabled
  #define DEFAULT_DIN_MENU_SNAPSHOT     0xff       ; disabled
thereafter build a new .syx file like described here: http://www.ucapps.de/howto_tools_mpasm.html
