I am building the powersuply for my sid using an old c64 power psu.  On the diagram for doing this it says that you can connect the power led from the C64, i havent got one, any alternitves?
any led will work...there's nothing special about the c64 led.  if you're using a display with a backlight, you don't even need an led, because the screen itself can act as your power indicator.  if the screen is lit up, the unit is on.
i think he just did it that way because the C64 led has a 3-pin socket at the end, even though only 2 of the pins are actually connected to anything.  you can see in the diagram that the third pin is connected to the first. i think this is done for orientation reasons; no matter how you connect the socket, the C64's power led is going to function properly.  the led itself, however, only has two leads...it's just a normal led.
let me know if this is unclear.
yes thanks,
i didnt have an actual led to look at, so thanks for clearing this up, i may leave this off once ive fitted the lcd
