Hi everybody  ;D
i have a little problem understanding the MIOS... :'(
I wanna assign bank up & bank down in two of my free buttons.
i successfully transformed, asm to hex, and hex to syx
but i'm not able to find the place where put code for the fonction
anybody can help me ?
simple not ?  ;D
(excuz my french english...)
oh yes excuze me  ???
it's for the midibox64
i wanna 2 buttons (up/down) for switch between my 128 internal banksticks banks.
It's for a live use, and it's too long to go to the select bank menu...
if it's possible to have this 2 buttons set permanently like the 4 menu buttons ?
not affected in each bank, but in the "heart" of the midibox64
thanks thorsten.
you could assign these buttons to the appr. special functions (a list can be found here: http://www.ucapps.de/midibox/midibox64_sfb_table.txt)
But this has to be done in each bank.
Ok, or you could call the MB64_SFB_Handler_02 function from MIOS_DIN_NotifyToggle, but this requires some additional code. I cannot provide working code for this solution before this weekend, so maybe it's better when you are using the already existing possibilities.
thanks very much
i don't know how to use special fonction, but i'm learning it...
if you have the time this weekend to tell me more about
the MB64_SFB_Handler_02 solution,
i appreciate very much, because it's seems to be a better solution for me.
hi Thorsten
it's ok i can find the MB64_SFB_Handler_02
but can't find MIOS_DIN_NotifyToggle ??
And when i use special fonction for 2 buttons
with the vmidibox64 program
the button only display the name & bank number
but don't change anything ?
any explanation ?
thanks  ;D
Thanks Thorsten
unfortunately the link doesn't work anymore  :'(
Hs : I use a simple copper board to test the touchsensor fonction
(with 47k ...) and when i touch the copper, the box send
in loop, 0, 127, 0, 127, 0, 127... is it normal ?
can it be disabled ?
i have find USER_DIN_NotifyToggle, and MB64_SFB_Handler_02 but
i don't know how to program the fonction  ::)
thanks very much Thorsten.
- Yes i have look to the schematic to DINX4
and i have connect the touchsensor (copper plate) correctly
but it still send 0,127,0,127,0,127 in loop, until i have the finger on the copper ?
it's the normal fonction of it ? really strange.
- For the dedicated Bank Up & Down button, anybody have the time to tell me more
about USER_DIN_NotifyToggle, and MB64_SFB_Handler_02 ?
after many try, i'm unable to realize my dream  :'(
Thanks Thorsten !
  • 5 weeks later...
to the touch sensors: you have to adjust the touch sensor sensitivity, this can be done in the editor or in the mk_syx script (see also http://www.ucapps.de/howto_tools/vmb64_2.gif)
DIN programming: no time, but maybe somebody else? Tip: learn how the DIN hook is working by reading the example programs (can be found in the MIOS download section) - they include a lot of useful comments. Thereafter just start to include your extensions into the MB64 application. You only need to increment/descrement the MB_BANK variable, thereafter brahch to MB64_BANK_Change, and thats all
