aleintrance Posted January 22, 2005 Posted January 22, 2005 Hi all!!My seq is up and basically working, but I still have some probs:1 - I've mounted alps stec detented encoders. When I turn of a click an encoder the parameter advance by 2 steps... Where have I to modify?2 - Some strange artifacts happens to LCD: sometime when I modify i.e. step 3, another step change visualisation, and after it show back the correct info. I've cleaned all the solder flux on LCD and Core boards3 - solo button and enter button doesn't work checked and rechecked with the tester it's ok. Is there a prg to test buttons and encoders?4 - sometimes pic restarts without logic....5 - bankstick not working (modify on pin 28 ok)Hope someone can help me.Sorry for my englishThank u in advance
TK. Posted January 22, 2005 Posted January 22, 2005 Hi,1) setup_mbseq_v2.asm: change MIOS_ENC_MODE_DETENTED to MIOS_ENC_MODE_DETENTED2(this will be the default setting in the next release)2) there is a known problem with such artifacts (see the (short) buglist), but they don't happen like described. This could be related to a problem with the DINs3) use the MIDIO128 application (buttons send one note event, encoders send two note events)4) bad solderings5) bad solderingsBest Regards, Thorsten.
aleintrance Posted January 22, 2005 Author Posted January 22, 2005 thank u thorsten for the fast reply I'll check all!
