       hey up
i made one of the old midibox 64  with the old firmware now im making a mios box and im at the stage of the boards made and wanting to program the pic
    but im confused can i not put mios into the new pic with a jdm programmer and if not how do i programme mios as  i dont have a midi connection to the core module at the moment
So, you're programming a 18F452? --You only have to program "MIOS bootstrap loader": http://www.ucapps.de/mios_bootstrap.html.. This can usually be done with a JDM...... (usually with some modifications)
Then the MIOS and the application downloads are done by midi.. that's when you have your midi connections ready, right?
..If your just getting a new Pic from Smash.. then ask for the programmed one, with the ID 00.. I think?
Bye, Moebius
But ask again if this is too confusing.
high
thank you for the info
im programming 18f452 with the bootstrap loader then through (usb) midi im loading mios and a midibox app if i follow the info right  just to clarify
                          thanx very much
Hi, there - I'm sorry, I'm not HIGH..  :o  :o  ::) (nor anyone around this forum - What would happen If Tk was..)
I think your ok. Your information is correct.
Bye, Moebius
    hey up
              then is that good for a greeting
              me im high on life all of the time especially when im working on finishing my traktor box
            thanx for the confirmation of info
