freecomm Posted February 6, 2005 Posted February 6, 2005 Greate work! I am new to this forum. I think this website is a greate DIY project. I want to know If the USB Module could be used to play and record wav file? Thanks.David
moebius Posted February 6, 2005 Posted February 6, 2005 Noo..It's "only" a midi interface. ;DThere are some USB audio circuits to be found on the internet - but those should really be considered as surface mount component soldering practice, with current audio interface prices.. I mean you'll probably end up losing money by building one yourself.Bye, Moebius
freecomm Posted February 6, 2005 Author Posted February 6, 2005 Thanks.Moebius. ;DI know little about the USB classes. But I think if we modify the fireware, it maybe a wav interface then.
Lall Posted February 8, 2005 Posted February 8, 2005 Hi Freecomm,Indeed, by modifying the firmware running on the EZ-USB, you can certainly make it a wav reader/player. I'm using the very same chip as a HID device, the black magic to change skin is mainly in the descriptors.There are however two things you need to consider:1) you need to get the samples in/out and therefore you need a DAC/ADC that can interface in a nice way with the EZ-USB. You should look at how they are implementing what they call Fast transfer mode or something of that kind; it's actually a kind of FIFO that can help you speed up considerably the transfer duration.2) you need to get a firmware up and running with audio class functionality. I've quickly looked at the spec from the USB site some time ago and that's quite indigestible. Finding a good sample on the web would be very much appreciated I presume. If someone knows about one, I'm interested as well ;)Best regards,Lall
